Conector 40 pins BM54
percu_mw
3 Ago 2007
Hola a todos.
Tras seguir las instrucciones del pineado
Cablear todo correctamente para poder tener una SALIDA AUX de sonido
que poder llevar a mi cajón Subwoofer, me encuentro, que los pines 1,3,7 no dan absolutamente nada a la salida. ( sonido = 0 patatero )
Con lo cual creo que hay dos posibilidades:
1º- Estos pines no dan nada de nada (ya encontré algún pdf en el que se indica "no fuction" para esos pines)
2º- Falte algo por activar en algún sitio para que tengan salida activa.
PD: Tengo un E46. BM54Prof+TV+Nav MK4 16:9 (KW: 27/04)
Pin out que yo encontré:
Pin No. / Wire Color / Function
Large Black Plug x18126
1 / Blue-Black / Right Rear + output to amp (twisted with 5 )
2 / Blue-Red / Right Front + output to amp (twisted with 6 )
3 / Yellow-Red / Left Front + output to amp (twisted with 7 )
4 / Yellow-Black / Left Rear + output to amp (twisted with 8 )
5 / Blue-Black / Right Rear + output to amp (twisted with 1 )
6 / Blue-Red / Right Front + output to amp (twisted with 2 )
7 / Yellow-Red / Left Front + output to amp (twisted with 3 )
8 / Yellow-Black / Left Rear + output to amp (twisted with 4 )
9 / White-Yellow bands / I-bus?
10 / White-Brown / Mute from phone?
11 / White-Green / ?
12 / Brown / Ground
13 / White / Remote on-off to amp
14 / Grey-Red / Dash illumination (dimmer)
15 / Red-Green / +12v from battery (not switched)
16 / Violet-White / +12v from ignition (ACC and RUN)
small white plug x13598
1 / / No function
2 / White-Brown / Audio common from 6CD player
3-7 / / No connection
8 / White-Red / Audio Left Channel from 6CD player
9 / White-Blue / Audio Right Channel from 6CD player
10 / / No Connection
11 / NAV / TV Audio +
12 / NAV / TV Audio -
NEW Small black plug: x13649 plug
1 / Tape left +
2 / Tape left -
3 / Left Connection for AUX Input
4 / Right Connection for AUX Input
5 / NAV / TV Audio +
6 / White-Black / Phone audio + Positive
7 / Tape right +
8 / Tape right -
9 / No connection
10 / AUX Input Ground
12 / Brown-Black / Phone Audio - Groundv
Bueno, pues todo eso. Perdón por el tocho.
W
Waky
tengo un cable de cargador de cd de 5 hilos uno rojo otro blanco otro negro gordo otro negro fno y otro gris yo ya tengo la preinstalacion echa pero me falta conectar el dichoso cable alguien me podria ayudar con algun brico de como adaptarlo necesitaba saber en que sitio va cada cable y el nº de pin que le toca
makso
X3 & R56d
31 Oct 2006
Rescato el hilo :)
Voy a montar un mki 9100 en un mini r56.
Tengo dudas respecto al MUTE. Va al pin 10, o no hace falta ponerlo???
Otra duda es que pienso ponerlo utilizando las entradas AUX IN.
entonces me sobra un monton de cables.
¿Irá todo bien?
UNIKA lo dejare para mas adelante. Si todo furula bien lo mismo me lanzo
Graciasssssssss
Tizon
R 1300GS
13 Jul 2003
makso;11517799 dijo:
Rescato el hilo :)
¿Irá todo bien?
Graciasssssssss
el mute normalmente no hace faltan en cuanto a utilizar la entrada aux in no te entiendo, no vas a utilizar el conector ISO>BMW ?
makso
X3 & R56d
31 Oct 2006
Afirmativo. No pienso utilizar el cable ISO-BMW.
He encontrado en este foro informacion dispar, algunos dicen que MUTE funciona, otros que no.
Si no funciona, voy a tener que meterle el cable ISO
Lo pregunto, porque desmontar r56 tiene castaña
gracias
Tizon
R 1300GS
13 Jul 2003
yo te cuento mi caso en lo E9x que he puesto el parrot daba igual poner el mute, el parrot hacia mute igual. pero claro yo utilizaba la salida de los altavoces no la entrada Aux :wink:
makso
X3 & R56d
31 Oct 2006
Gracias, tizon
Ya lo tengo desmontado.
el sietema no tiene mute, utiliza canbus H y canbus L.
La radio SI tiene pin de mute. Probare a ver que tal
saludos
makso
X3 & R56d
31 Oct 2006
Ofu, que trabajera madre mia.
ya vas 2 dias completos, jajaja.
Parrot presentado, probado y funciona. Solo falta montar el salpicadero.
Sigo tenieno dudas sobre el MUTE.
El pin 10 me da 12V permanente ¿?¿?¿?
No entiendo porque
Alguien sabe algo?
rreeoo
16 Oct 2011
Aunque llego un poco tarde te contesto en base a un E90 LCI 2010:
El conector 9 y 11 son Can H y L
El conector 10 es Mute.
Las señales de Mute suelen ser negativas en dirección del Parrot a la radio logicamente, si te da la radio una señal positiva puede ser simplemente por el diseño, por ejemplo, si miras la polaridad del cable de las luces positivo cuando están apagadas también te da negativo, porque la masa pasa a través de las bombillas.
Yo tengo previsto conectar también el parrot por la entrada aux pero creo que si conectas la señal de Mute cuando uses el parrot la radio activa Mute y da igual que tengas un CD o AUX in o Radio puesta, hace Mute y no deja escuchar nada (salvo la entrada Tel + y Tel - de los pines C6 y C12, si no me equivoco)
Si puedes cuentanos al final como te funciona y como lo has conectado
