rave
- Modelo
- F32
- Registrado
- 12 Abr 2007
- Mensajes
- 2.912
- Reacciones
- 170
Bueno, he encontrado una lista interesante. Muchos de estos no sirven para nuestro coche ya que no tenemos la centralita igual, pero otros pueden valer. O pueden valer de referencia para buscar nuevas opciones en nuestros módulos.
Control unit: Cappl
MDrive
nicht_aktiv -> active
HUD_M
Control unit: HUD
M_SPORT_HUD
nicht_aktiv -> aktiv_handschalter
[Turn indicator in the HUD]
Control unit: HUD
BLINKER_AUSSTATTUNG
[Reel speed or tachometer option in the onboard computer]
Digital speedometer in the vehicle computer.
Control unit: COMBINATION
BC_DIGITAL_V
BC_DIGITAL_V_KORREKTUR
active / nicht_aktiv
[Permanent instrumentation lighting]
The speedometer light despite the lights always on first ignition
M_TAG_SKALENBELEUCHTUNG
[Blank line in the paste-board computer]
BC_LEERZEILE
[Speed settings for climate control display]
The current fan speed is displayed even in the automatic operation of the air conditioning.
Control unit: IHKA
GEBL_ANZEIGE_AUTO
[No automatic. Compressor] with climate control
When you press the automatic button will no longer switch automatically sets the air conditioning.
Control unit: IHKA
ABWAHL_AC
[Spiegelanklappen on the remote key]
Connect with the comfort = longer pressing the Connect button on the remote control.
Control unit: KGM or TMBT and TMFT
BEIKLAPPEN_B_KOMFORTSCHL
[Roof rain Close]
with rain sensor is activated.
Control unit: SHD or HSDH
RAIN CLOSE
If with respect to the coding, an error message comes the pinch:
- Ignition on
- Ensure that the sunroof is closed
- Press the key to lifting / tilting the sunroof and hold (approx. 1 minute) until all settings have been hit once and the sunroof is closed.
[Comfort tailgate open and close]
Komfort-Öffnen/Schließen = longer pressing the open or close button on the remote.
Control unit: HKL
KOMFORT_OEFFNEN_HKL
KOMFORT_SCHLIESSEN_HKL
Tailgate by pressing only once on the key itself include:
FUNKTION_FBD_SCHLIESSEN_2
Tailgate to close the switch in the foot:
FUNKTION_TOEHKI
[TV / Video while driving activation]
Control unit: Cappl
VIDEO_DENY_C0B
deny_slow_key -> deny_never
[Entry aid steering wheel height adjustment de-/activate]
Control unit: tractor
EINSTIEGSHILFE_HOEHE
active -> nicht_aktiv
[Steering wheel button function "next entertainment source" Add]
Control unit: Cappl (from the first software release CCC_APP.C0A)
NEXT_SOURCE
AM Tuner skip:
AMBANDS
[IDrive options for acoustic locking and unlocking Add (with DWA)]
Control unit: Cappl or MASK
ACOUSTIC
C941C_QUITT_AKUST_KLAPPE
fkt_gesperrt -> fkt_frei
K9416_QUITT_AKUST_ENTSCH
C9413_QUITT_AKUST_SCHAERF
[Change the alarm sound of the beeping of the DWA to howl]
Control unit: DWAS
ALARM TYPE
U.S.
[Advanced maneuvering in the iDrive menu]
for example, a rear-view camera is connected via LVDS.
Control unit: Cappl
RVC
RVC_CONNECTED_TO_VM
nicht_aktiv / active
RVC_DISPLAY_OPTIONS
main_or_fullscreen / only_fullscreen only_mainwindow /
[Seat climate menu in the iDrive]
Control unit: Cappl
VA_AIRVENT_SHORTCUT
VA_SEATCLIMA_SHORTCUT
VA_SEATHEAT_SLIDER
VA_SEATVENTILATION
SITZHEIZUNG_APP_9
[SMS display in the iDrive]
Control unit: Cappl
SMS
[Notepad complement in the iDrive menu, phone]
Control unit: Cappl
NOTEPAD
[Comfort Open (2 times to open the remote control) to the driver's window semi]
Control unit: Cappl
K931D_SCHEIBENABSENKUNG
par_gesperrt -> par_frei
[Light sensor sensitivity settings menu in the iDrive]
Control unit: Cappl
RAIN_LIGHT_SENSOR
C750A_SCHWELLWERT_EMPFIN
C750A_SCHWELLWERT_NORMAL
C750A_SCHWELLWERT_SEHR_E
and vehicle application by:
FLCN + = normal threshold
+ FLCS = threshold very sensitive
[Light sensor sensitivity setting]
Control unit: RLS
FLC_SCHWELLWERT_SATZ
wert_01]
wert_04] = sensitive
wert_02 = normal
wert_03 = very sensitive
[Daytime running lights non LCI]
VFL headlights with LM1:
Control unit: LMA
DRL_V_GEDIMMT
nicht_aktiv -> wert_01 = Indicator -> wert_02 = beam
DRL_WERT_DIMMUNG
wert_01 = 26% -> wert_02 = 40%
Daytime running lights on the main (only LM2):
VERHALTEN_DRL_TFL_33
drl_tfl_off -> drl_h -> drl_s -> drl_l -> tfl_s
U.S. daytime running across the beam (only halogen beam and LM2):
drl_h
PWM_FL_FKT_DRL_33
wert_01 to wert_03 = Dimmungswert
[U.S. indicators with side turn indicators on parking lights or headlights]
Control unit: LMA
DRL_TFL_BLK_V_GED
PWM_SIDEMARKER_BLK_V
wert_01 = off
wert_02 = light
wert_03 = dark
[Side marker lights with daytime running lights activated (only LCI)]
Control unit: LMA
SL_V_MIT_TFL
active
[As cornering fog lamps with LM2]
! Works! Jakober not loud! Request for feedback
Control unit: LMA
PWM_FL_NSW_FKT_ABBLIEGELI
wert_01 -> wert_02
[Cold and hot control of the lamps]
Control unit: LMA
KALTUEBERWACHUNG_
KALTUEBERW_
WARMUEBERWACHUNG_
WARMUEBERW_
FEHLERMELDUNG_CC_
RFS_R, RFS_L = Reverse Light
FL_R, FL_L = beam
AL_R, AL_L = cornering
SL_V_R, SL_V_L = parking light
NSW_R, NSW_L = fog
BLK_V_R, BLK_V_L = flashing front
BLK_H_R, BLK_H_L = flashing back
BL_M_1 = 3 Brake light
KZL_R, KZL_L = plate light
NSL_R, NSL_L = rear fog lamp
TFL_R, TFL_L = Daylight
SML = Side marker lamps
BL_R, BL_R = brake light
RL_BL_1_R, RL_BL_1_L = tail light brake light 1
RL_BL_2_R, RL_BL_2_L = tail light brake light 2
[Welcome Light]
Only works with light module 2 (LM2 all LCI or all VFL 09/2006 have with xenon and adaptive headlights) and the light switch in automatic position + position 1
Control unit: LMA
WELCOME_LIGHT_ACTIVE
WL_AL = low beam
nicht_aktiv / hart_einschalten
WL_BL = brake light
nicht_aktiv soft_einschalten / / hart_einschalten
WL_BLK_H = Left Rear
WL_BLK_V = front indicator
WL_FL = beam
WL_KZL = plate light
WL_NSL = rear fog lamp
WL_NSW = fog
WL_POL = position or the front parking light
WL_SL_1 = closing or parking light rear 1
WL_SL_2 = closing or parking lights, rear 2
WL_SM = Eyebrow
[Coming Home Light only VFL]
After switching off the engine and operate the ignition, the flashing briefly.
Control unit: LMA
HEIMLEUCHTEN_
[Eyebrow / off]
Control unit: LMA
SIDEMARKER_US
[Flash light with bi-xenon]
Control unit: LMA
BI_XENON_BEI_LH
[Interior of brake lights during normal braking (only VFL Taillights)]
Control unit: LMA
RL_BL_1_BREMSL_FKT
[Beam with the Xenon headlights and not also on the high beam-H7 (only VFL)]
Light switch to automatic:
Control unit: LMA
FL_AUS_BEI_BIX_IN_S_FLC
active
Light switches in all positions:
Control unit: LMA
PWM_ANST_FL_BIXENON
wert_03
[Beam and fog lamps are not simultaneously]
Control unit: LMA
FL_UND_NSW_NICHT_GLEICHZ
[Flashing adaptive brake lights (Break Force Display)]
In an emergency stop flashing the lights.
Control unit: LMA
BFD_1_RL_BL_ERSCH_BILD = brake light
wert_03 = flashing
BFD_1_BL_M_ERSCH_BILD = 3 Brake light
wert_03 = flashing
BFD_1_RL_BL_1_ERSCH_BILD = brake light 1
wert_03 = flashing
BFD_1_RL_BL_2_ERSCH_BILD = brake light 2
wert_03 = flashing
BFD_1_NSL_ERSCH_BILD = rear fog lamp
wert_03 = flashing
[Warning light on de-/ activate]
Control unit: LMA
LICHT_AN_WARNUNG
[Zündschlüsselwarnung de / activate]
CC_ZUENDSCHLUESSEL
[Acoustic seat belt warning disable]
Note: The effect on the release behavior of the air bag is unknown.
Control unit: ABG
SBR_BEIFAHRER_ACSM
SBR_FAHRER_ACSM
or a vehicle, contracting with the value:
+ OI11 for the driver
+ OI12 for the passenger
and
to 03/2004:
SBR_BEIFAHRER
nicht_aktiv
SBR_FAHRER
nicht_aktiv
from 03/2004:
Control unit: SGM
SBR_BEIFAHRER_SGM
nicht_aktiv
SBR_FAHRER_SGM
nicht_aktiv
09/2005:
Control unit: ACSM
SBR_BEIFAHRER_ACSM
nicht_aktiv
SBR_FAHRER_ACSM
nicht_aktiv
[Passenger seat occupancy sensor mat disable]
Control unit: SBSR
SBE1_SBSR
nicht_aktiv
or
Control unit: ABG
SBE1_ACSM
nicht_aktiv
[Home Comfort]
The ignition key must be touched only briefly to the ignition to start the car.
Control unit: CAS
HOME COMFORT
[PDC volume change]
Control unit: PDC
LAUTSTAERKE_HINTEN
e65, e60, RR1, e70, wert_02 to wert_07
LAUTSTAERKE_VORN
e65, e60, RR1, e70
[Engine start only when the brake pedal depressed, de-/ activate]
Control unit: CAS
ANLASSSPERRE_BLS
[MP3 functionality upgrade]
KMP3 in the FA-supplemented
Control unit: Cappl
MP3_CCC
full
[IPod interface retrofit]
IPOD in the FA supplement
Control unit: Cappl
MP3_CCC
external or full
CDC
active
[AUX-IN interface upgrade]
NAUX in the FA-supplemented
Control unit: Cappl
AUX_CONFIG
mounted
INPUT_SCALING_SUB2
wert_02
ya me imaginaba que iba a funcionar. yo hice un monton de cosas mas :-& pero ha salido bien el simplificado jajajajj
