Hilo BMW Coding Serie 3
gmros
20 Jul 2011
cómo se actualizan los módulos con el winkfp? alguien que lo explique para dummies :descojon::descojon::descojon::descojon:
zorbmw
10 Sep 2009
gmros;12416593 dijo:
cómo se actualizan los módulos con el winkfp? Alguien que lo explique para dummies :descojon::descojon::descojon::descojon:
Acabo de encontrar estas dos formas :
nstructions on how to update a module with WinKFP.
1 Start WinKFP and select F3:- Update ZUSB
2 Select ECU type and the ECU will appear along with a list of part numbers.
3 Select ok and the main menu will re-appear
4 Select VIN and enter the cars VIN no. and select OK.
5 Select Done
6 Select Prog. ZB_update, you will be asked to confirm the update, Winkfp wil state the number of times the module can be re-programmed.
7 Sit back and wait.
I did my TCU with my cars VIN no. and it took 35 mins over the OBD port.
No, You will not need the old ZB#, you will only need the ZB# from the DME module you want to update. I will give you a short instructions on how I use WinKfp to program my modules.
1. Go into INPA and print off the complete UIF page with ZB# and programming info.
2. Close INPA completely and launch WinKFP.
3. I use comfort mode since it does everything that I need it to do.
4. Once you are in comfort mode, Click on Choose ZUSB and make sure that the programming data is loaded in there. If you dont have any data in there you will need to load it before you proceed to the next step.
5. Close the window that is showing the programming data and click on Enter Vin, Enter your complete VIN # of the car you are programming, and click OK, Vin will show up at the top of the program if it accepted it.
6. Click on Enter ZUSB and enter the ZB# from the UIF printoff from INPA, and click ok.
7. It should load the next window and show the module # and something in the right screen. You can leave those as default and click ok.
8. Click on Done, which will bring you to the programming page.
9. Make sure you car is hooked up to a battery charger before you start the programming.
10. Once you have everything good to go click on program and sit back and relax, it will go through and will say " You have 1 time left to program this ECU" click OK and it will flash it.
haber si nos confirman la forma mas correcta de actualizar
zorbmw
10 Sep 2009
una duda que me surge, al actualizar si el modulo tiene un VIN distinto al de tu coche te deja actualizar ? o actualiza y te lo cambia a tu VIN?
gmros
20 Jul 2011
zorbmw;12417183 dijo:
creo que lo actualiza y cambia el vin al que tu le pongas. a ver si nos confirman esto y cómo actualizarlo.
ruben_17non
Bmw E92 y X4
10 Abr 2011
1/Abrir Inpa ir a la seccion UIF apuntar el numero ZUSB del modulo que queremos actualizar.
2/Abrir Winkfp, (suponiendo que estan los datos del modulo importados)
-F1 Confort Mode
-F1 Enter ZUSB, Meter el numero ZUSB del modulo.
3/Se nos habre una pantalla nueva del estilo a esta>
-Atentos a la primera columna Family ECU, quedara seleccionado el tipo de modulo en este caso MS5150.
-Le damos a OK
4/Con el tipo de modulo (Acordaros de el) Pulsamos F3 UPDATE ZUSB buscamos el modulo que queramos actualizar sera el mismo que nos ha salido antes en este caso MS5150 y pulsamos OK
5/ F4 Enter VIN metemos el VIN completo pero sin el check digit.
-Pulsamos F8 DONE
6/Por ultimo F3 Program
Hay varias formas de actualizar con winkfp, de esta forma aseguras cual es el modulo, se puede hacer con menos pasos...
Si os sale algun error al meter el ZUSB en el primer paso es por que no estan importados los DATOS de ese modulo.
Cuidado con lo que haceis... el DCAN no es recomendable para esto.
ruben_17non
Bmw E92 y X4
10 Abr 2011
SI deja actualizar, Le puedes poner el VIN que quieras.
gmros
20 Jul 2011
ruben_17non;12417778 dijo:
-F1 Confort Mode
-Le damos a OK
-Pulsamos F8 DONE
siempre con cabezal y estabilizador de corriente
:zartyman
xWeST
10 Feb 2011
Alguien sabe a qué se puede deber esto?
xWeST
10 Feb 2011
He reinstalado la máquina virtual y configurado de nuevo las conexiones del cabezal de diagnóstico. Llego por ping 192.168.68.1 y telnet al puerto 6801 a ambas máquinas, pero no establece la conexión.
xWeST
10 Feb 2011
Robertito24;12422552 dijo:
¿Tienes bien configurado los vm1 y 8?
Creo que sí, cómo se configuran? Si llego por ping y el telnet conecta será que sí imagino.
Robertito24
3 Nov 2007
Inicio / Todos los Programas / VMWare / Virtaul Network Editor
Y ahi configuras las 2 vm1 y vm 8
xWeST
10 Feb 2011
Robertito24;12422729 dijo:
Qué configuración tiene la vm8?
Robertito24
3 Nov 2007
VMnet1:
Host-only y los dos check los marcamos ("Connect a host virtual..." y "User local DHCP"
Subnet IP: 192.168.68.0 Subnet mask: 255.255.255.0
VMnet8:
Host-only y los dos check los quitamos ("Connect a host virtual..." y "User local DHCP"
Ahora Apply y OK.
edupi
530d F10 AUT M
5 Ene 2007
Otro mod para que baje el espejo con el bordillo, espejos electricos... en NFRM
SPIEGEL BORDSTEIN AUTOM
aktiv
esto se supone que solo funciona para el que tenga asientos con memoria no? o se puede engañar.
edupi
530d F10 AUT M
5 Ene 2007
Robertito24;12426693 dijo:
Si lo llevas pineado y metido el VO activas eso y te debe de funcionar
ok probare haber como lo hago otra cosa por si vosotros habeis indagado tengo activado esto y va bien hay alguna manera que al igual que se activan las largas al poner contacto se puede poner los angel eyes o en el caso del e60 las cejas?
Luces de dia en largas a baja intensidad:
En módulo LMA
Drl_v_gedimmt
wert_02
jazza
FORD PUMA
3 Nov 2007
edupi;12426613 dijo:
aktiv
Mis asientos no tienen memoria y va, pero claro, yo lo pedí como opción de fábrica.
Si solo fuera cuestión de activarlos en el módulo vaya timo #-o aunque tampoco me extrañaría...biggrin
zorbmw
10 Sep 2009
aktiv
Según tengo entendido funciona en todos los espejos que se abaten electricamente no hace falta tener memoria
edupi
530d F10 AUT M
5 Ene 2007
zorbmw;12427876 dijo:
Mis espejos son electricos de serie y se cierran y habren y esa opcion la hace a los q tienen asientos con memoria ojala y me equivoque por eso preguntaba probare a ver si hace algo.
zorbmw
10 Sep 2009
edupi;12428117 dijo:
Puede ser que activandolo te funcione, de todos modos me refiero a e90 y e87 aun que no estoy seguro del todo... De serie 5 ni idea
MoiMconcept
12 Abr 2005
Hola Alguien tiene un interface bmw dash scanner v2.20 que me pueda decir que pinout tiene?
yo tengo un v.201 y en mi e92 no conecta..
queria transformar mi interface a d+can..
PD: ya he probado lo del cable 7 y 8 (Venian originalmente unidos..)
Gracias!
Jose_JN
3 Ene 2007
jazza;12427776 dijo:
Tus espejos SÍ tienen memoria.
Todos los espejos que abaten tienen memoria :)
Sólo tienes que abrir el coche con las dos llaves y cada llave dejará el espejo en donde lo cerraste :guiño:
Lo que no tienes son los asientos con memoria y los botones para cambiar entre ellas (incluidos los espejos)
topieiro
Baneado
Baneado
23 Nov 2012
MoiMconcept;12428463 dijo:
Gracias!
Vecino con un m3 pillate el dcan que vale cuatro duros hombre
MoiMconcept
12 Abr 2005
Es que tengo ese ya.. y se que es una tonteria y por aprovechar el interface. esperare a ver uno.. y ya le hare la modificacion con un swicht para hacerlo bi canal.
pd: ya pedi un dcan.. jeje
gmros
20 Jul 2011
buenas, se puede registrar el cambio de batería en nuestros coches con el ncsexpert? alguien sabe el proceso?
gracias.
zorbmw
10 Sep 2009
gmros;12435759 dijo:
gracias.
con el ncexpert??? en todo caso seria con inpa o Dis no?
gmros
20 Jul 2011
zorbmw;12435815 dijo:
no tengo ni idea, pero si fuera con el dis o el inpa también perfecto. alguien sabe cómo se hace?
saludos
tururu33
118d Coupe
10 Feb 2009
buenas, se puede registrar el cambio de batería en nuestros coches con el ncsexpert? Alguien sabe el proceso?
Gracias.
Aquí lo tienes.
robertito24;12343346 dijo:
abrimos tools32
abrimos archivo msd80.prg
buscamos steuern_batterietausch_registri
y ejecutamos run job
