Fotos Scarabaudi,Puchische,Vwulgartti,Fauxrrari, Merchuzu, Asere-G, AUDacia, Toydiota... VOL II
Hunkt Canticie (n)
Barbinski
PHEV tester
Q5-Q5sb-S2R1000
18 Mar 2004
:eek::eek:
Interior.
Lo del volante es para manejar a una mano ? hacer contravolante más eficientemente?..:nose:..se escapa a toda coherencia
Ains...ooootro Fierrari...F40 base Pontiac. piden 25.000 pavos
Estas réplicas de un artista en Tailandia molan un webo :devil: Mercedes 300 SL y AMG GT-R, Ferrari 250 GTO, 2 Bugatti Chiron...
Fieroghini 300 alCountado ...
I Just Bought A FAKE Lamborghini For $300
Hondarghini Civictador SVJ
Mira que gusta replicar los Lambos, hay un body kit de los japos Albermo para convertir el Toyota Venza en un zarriUrus :pompous:
Hyundai Accent to Ford Mustang 1969
10 jul 2021
Dream Customs India
Modified Hyundai Accent convert into Ford Mustang 1969 model by Dream Customs India costing for modification is 8 lakh plus donor car its takes 4 months for converting please call or what's app 9521061810 for more details.
Replica Ferrari vs Real
4 jul 2021
Replica Ferrari 458 - Interior
A la venta en Canada, lo mejor... que al final del anuncio pone que no es un Lambo biggrin
https://www.facebook.com/marketplace/item/527593178343550/
60,000 KM, Invidia High Performance Exhaust, 18" Performance Wheels. Punch Sound System, Backup Camera, Cruise Control, HD Radio, USB, Aux, Bluetooth, No Accidents, Clean Carfax. Original Colour is Black with Gold Wrap. Factory Emblem Changed by previous Owner. 2017 Toyota FT-86 with low km, Safety Certified. Disclaimer: This is not a Lamborghini.
Lo venden aquí, solo piden 69K $... bonito número biggrin
https://chicago.craigslist.org/chc/cto/d/chicago-2011-mercedes-benz-c8-might/7368582370.html
2011 Mercedes Benz C8 might TRADE TRADES - $69,000 (Chicago Peterson and Western)
2011 Mercedes-Benz AMG C8 GTR streetable / legal, road race car with thoughts of running the LeMans, Sauber, Autobahn.
This concept is inspired by the C8, C9, C11, Mercedes Benz road race cars. It starts right up with these, has all the features of the modern cars, horn, heat, wiper, lights all functional. It steers with ease, all the wait is in the rear the car. This car is about 6 to 8 inches wider than your average car which makes it very easy to handle around the terns. It has independent suspension all the way around a V8 SBC 350 engine mated to a heavy-duty 6 rib 4 speed transmission with four wheel disc breaks, It has Gullwing doors a Full Tilt rear body For accessing the engine compartment. A hood that opens in front to access the master cylinder and the aluminum radiator this is a one-off build both Frame and Body as you can see in the picture's. I am 5.9 tall 250lbs so I would say it fits a big guy if needed with room to spare. It has some real nice auto meter gauges fitted into carbon fiber panels with a carbon fiber steering wheel and shifter knob to match. A nice up-to-date stereo that you can play music off your phone if you like, with a 3-point roll bar behind the seats also the seats are custom made black outer with alligator in the center diamond plated it has nerf bars on the rear with a fairly quiet exhaust system. I would say this car draws more attention than any car I have ever owned and I've had my share of wicked rides. This build is quite a few steps above average the picture show almost everything this car runs on pump gas 89 to 93 otc.
This is a list of the parts,
350 Chevrolet Eng,
aluminum louvered air filter housing that match valve covers and ignition wire Looms that are also aluminum,
aluminum oil pan with louvers,
Edelbrock carburetor # 1406-2821 with electric choke housing,
Street electric fuel pump Quite with two fuel filters going to a 25 gallon fuel tank,
polished aluminum high rise intake manifold,
big GM HEI distributor with Taylor Pro 8 millimeter wires
R44TS spark plugs,
Chrome GM alternator single wire,
aluminum hi flow water pump,
Chrome pulleys and harmonic balancer, Chrome timing chain cover,
aluminum radiator with chrome electric fan also big Electric fan in engine compartment,
rubber motor mounts and transmission mounts,
GM exhaust manifolds number 140 93654 8 RH and GM 64753 9 lh,
Chrome manifold covers,
dual exhaust with cherry bomb mufflers not loud at all with chrome exhaust tips, hydraulic clutch with a heavy-duty 906 six rib transmission,
Dual driveshafts with universal joints, 350 Chevy engine # GM3970010
nice power distribution box / fuse box with relays and up-to-date fuses going as high as 50 amps,
dual Reservoir master cylinder with 4-wheel disc brakes,
front brake pads # MKD378
Rrear brake padsZd906
tilt engine compartment housing,
12-volt battery with 690 cca's,
m*roso air housing,
front and rear sway bars,
Auto Meter gauges, volt, fuel, speedometer, tachometer, oil pressure, water temperature,
carbon fiber steering wheel and shifter knob to match also Dash panels are carbon fiber,
aluminum clutch brake and gas pedal,
black custom seats with alligator design Inlet also diamond plated,
RCI seat belts yellow,
3 point roll bar,
nerf bars in the rear,
power actuators for trunk and wing doors, AM FM Bluetooth stereo,
Xpods coaxial speakers,
heater box and the ventilation system for cockpit,
electric wiper,
rear trunk spoiler,
cowl inducted Hood open too cool radiator,
custom hinged fuel door on top of right fender,
Aero Dynamic mirrors
LED marker lights,
rack-n-pinion steering
tilt steering column,
custom aluminum wheels, new tires all four, fronts are 205/ 50 R15, rear tires are Avenger GT 295/50r15
I like trading up or down my asking price is $75,000 call and ask questions if you like Ian 773 771 689three
Chevy CagayVette C7 biggrin ...que rima con retrete :LOL:
Mustang Cabrio Bocanegra Edition
vamos a disfrutar como se merece todo viernes:
Easy Rods hace este Thunder...shit
Vetterrari.. pero rari rari biggrin
Julai eléctrico vestido de Martini, a lo Deltona o_O... será vermú sin alcohol biggrin
Se ve un trabajo bien hecho, pero me duele que lo hagan con un Z...
BMW Z3 - AC COBRA Tribute | made by COACHWORK CASSICS
16 oct 2021
1999 BMW Z3 2.0 [ 6-Zylinder ] rebuilt as one of the most famous sports car classics in the world: AC Cobra. This Z3 was converted by the sports car manufacturer Coachwork Classics based in England. The entire technology is BMW Z3, only the body except for the doors is made of polyester.
RR... Rolls Robado, Range Rabo, Rollange Roycever :facepalm:
