Compact Muchos fallos en bmw scanner
Kikolin90
Bmw 318ti SWAP
27 Dic 2018
Buenas tardes forer@s!!! Resulta que e echo mi primera diagnosis en el coche con bmw scanner y me ha salido una ristra de fallos exagerada, como no tengo ni idea de que son os los dejo todos escritos a ver si me podéis echar una manilla por favor a ver si los puedo solucionar todos!!! Gracias por vuestra ayuda!!!
DME
(amarillo) 2781 [10113] camshaft sensor inlet.
(rojo) 2721 [10017] Lambda sensor ageing after cat.
EWS
(Rojo) 0F[015] power on reset.
(rojo) 13[019] toleration of changing code increased, key 1.
(amarillo) 12 [018] Wrong changing code, key 1.
(amarillo) 11[017] Wrong password key 1
ABS
(amarillo) 5E24 [24100] Pressure sensor 1/2 not plausible.
(amarillo) 5E14 [24084] CAN timeout DME/DDE
(amarillo) 5E16 [24086] CAN timeout instrument cluster
(Rojo) 5E43 [24131] steering angle sensor internal
(rojo) 5E1F [24095] PT-CAN chassis number wrong / ECU not initialized.
LEW
(rojo) 0B [011] wrong LWS-ID
(rojo) 09 [009] No CAN message (ASC)
A/C
(rojo) 1C [028] AUC sensor
(rojo) 1E [030] AUC heating
SRS
Shadow:
(amarillo) 70 [112] seat occupancy detector, break of seat mat
(amarillo) 81 [129] sensor for side airbag, left communication faul
(amarillo) 02 [002] driver's belt tensioner, resistance too high
IKE
(amarillo) CE [206] Outside temperature sensor
(Rojo) BF [191] internal fault EEPROM checksum 1(BMW section), coding imcorrect/incomplete
(amarillo) No CAN message (DME 1)
(amarillo) No CAN message (DME 2)
(amarillo) No CAN message (DME 4)
LCM
(amarillo) 22 [034] HVAC, front load sensor, short circuit to ground
ZKE
(amarillo) 30 [048] K-Bus or control unit for instrument cluster basis (Gateway)
Shadow:
(rojo) 8A [138] alarm memory. Radio interior protection.
(rojo) 90 [144] battery voltage. Open circuit
SZM
(rojo) 02 [002] seat heating left, short circuit or open circuit
(amarillo) 04 [004] temperature sensor seat heating left, open circuit
Shadow:
(amarillo) 05 [005] seat heating lower voltage recognised.
Eso es todo compañeros, de todas maneras voy a borrar todos los fallos y voy a hacer 60 km con el coche, a ver que es lo que vuelve a salir...
Un saludooo
joel
325ci E46 SWAP
1 Ene 2017
borra los fallos primero, todos los fallos que estan en amarillo son fallos que han sucedido pero que ahora no esta fallando. Los mas preocupantes son los rojos, de todas formas, borra todo, circula unos dias y vuelve a hacer diagnosis. Ya nos contaras!!
Kikolin90
Bmw 318ti SWAP
27 Dic 2018
E borrado y se han ido unos cuantos fallos, hay algunos que continúan, dentro de dos o tres días volveré a hacer diagnosis
joel
325ci E46 SWAP
1 Ene 2017
Una pregunta, tú tuviste que soldar los pines para que leyese todos los módulos??
Kikolin90
Bmw 318ti SWAP
27 Dic 2018
No, lo compre en Amazon y me ha llegado así, de echo creo que funciona bien no?
joel
325ci E46 SWAP
1 Ene 2017
Sisi es que abrí un post ahora mismo y era por saber si también te había tocado soldar. En tu caso va bien
Kikolin90
Bmw 318ti SWAP
27 Dic 2018
Por cierto, es posible que algunos de estos fallos sean debidos a que cambie le motor del 316 por el del 318?
chezztos
316Ti,323Cabrio
1 Jun 2007
No te asustes,yo la primera vez que meti el bmwscanner al mio me jiñe de la cantidad de errores que salieron:LOL:
Despues de tantos años habia muchos errores que estaban memorizados pero al borar se fueron todos
Kikolin90
Bmw 318ti SWAP
27 Dic 2018
Pues e borrado y algunos se han ido, pero muchos se han quedado
Kikolin90
Bmw 318ti SWAP
27 Dic 2018
Los de ABS, LEW, A/C Y SRS no se han ido....
Kikolin90
Bmw 318ti SWAP
27 Dic 2018
Mañana le meteré el scanner otra vez que llevaré 200 km echos a ver k sale...
juanjete33
320i 2.2 Steptronic.
30 Dic 2008
Pues tienes mal el sensor de angulo de giro y entre esos seguro hay algo que tenga que ver con el cambio de motor, dependiendo que mas cambiaras.
Kikolin90
Bmw 318ti SWAP
27 Dic 2018
Lo único que cambie fue motor y cargar los mapas de la centralita del 318 en la del 316, todo lo demás esta de origen? Donde está dicho sensor? Un saludo!! Graciass
318D
20 Feb 2021
Buenas compañeros, estos errores me salen con el bmw scanner y son los que mas me preocupan, aparte me ha salido dos o tres más pero que los tengo localizados y se de que son pero estos me salen todos en amarillo y el scanner no me deja borrarlos, alguna orientación, por favor?
(amarillo) 5E43 [24131] steering angle sensor internal
(amarillo) 5E1F [24095] PT-CAN chassis number wrong / ECU not initialized.
(amarillo)5DF4 .24052. Vehicle power 9 volt
Gracias de antemano.
Eduma
320 CI CABRIO
21 Oct 2005
Los errores en amarillo no son fallos presentes, son errores que en algún momento ha tenido y BMW Scanner no los borra todos porque es un Software pirata, no debes hacerles caso, únicamente a los que aparezcan en rojo.
Camigpr
Bmw 320 compact
23 Ene 2023
Buenas foreros!!He metido BMW scanner y me sale estos fallosa mi también....
Error abs
5E1F[24095]pt-can chasis number wrong/ecu nota initialized.
5E1E[24094]cam timeout lws
5E14[24084]cam timeout DME/DDE
5E16[24086]can timeout instrument cluster.
5E11[24081]can-bus off.internal error can-controller.
Error IKE
No CAN message (SMG1)
Error SRS
Driver's airbag stage 1. resistance too high.
Agradecería mucho si alguien me pudiese ayudar como solucionarlos!!muchas gracias foreros!
Camigpr
Bmw 320 compact
23 Ene 2023
Buenas foreros he metido BMW scanner y me da esta serie de fallos 5E1F[24095]
PT-CA chassis number wrong/ECU not initialized
5E16[24086]
CAN Timeout instrument cluster
5E1E [24094]
CAN Timeout LWS
5E14[ 24084]
CAN Timeout DME/DDE
5E11 [240811] CAN-Bus Off internal Error CAN-Controller
Haber si alguien porfavor me puede ayudar a cómo solucionar los fallos
