M5 E60 biturbo
@lexis
The worlds one and only Twin Turbocharged M5.
One would have thought that 508bhp was more than enough for this 4-door monster, but Currency Motor Cars (CNC), have ingeniously placed not one but two turbochargers at the rear-end of the car.
Press release:
Currency Motor Cars is proud to introduce the first of an unprecedented line of supercars. This flagship model is an ingeniously modified 2006 BMW M5 that can reach a top speed of 240 mph. This makes it the fastest, most powerful luxury 4-door sedan on the planet. CMC co-founder, Ron Cash, has brilliantly outfitted BMW’s compression V-10 engine with twin-turbo chargers and a custom inter-cooler system to kick out an astonishing 800+ horses. No one in the world has been able to achieve this...until now.
This is the only car of its kind.
The mind-boggling power of this vehicle is complimented by the exquisite alterations of it's interior. The leather in the steering wheel, arm rests and dash is the same as the leather in the seats. Fully aniline dyed Florida alligator in black. Only the finest suede and leathers have been used, much like the old Delahaye and Bugatti roadsters in the 1930's. This custom interior is all meticulously hand stitched, designed and installed by Judy Amic-Angelo, one of the the most respected product designers in the country.
Specifications
MAKE: BMW
MODEL: M5 E60
YEAR: 06 / 07
COLOR: Black
WEIGHT: 1830 kg
VEHICLE TYPE: 4-Door Sedan
PRICE: $350,000
ENGINE TYPE: High Compression V-10
COMPRESSION RATIO: 12.0:1
DISPLACEMENT: 4.999 cc
MAX POWER (bph): 810 hp
MAX TOURQUE (lp-ft): 733
VALVETRAIN: Four (4) valves per cylinder
TRANSMISSION: 7-Speed SMGIII
SUSPENSION: Koni struts and dampers, H&R Coilover springs, lowered by 1.5”
BRAKES (front / rear): Fourteen inch (14”) rotors
WHEELS: Asanti 120, 3-piece forged wheels (20-inch diameter)
TIRES: Pirelli P-Zero Nero
0 – 60: 3.6 Seconds
TOP SPEED: 240 MPH (est)
TURBOS: Custom CMC twin turbo design
INTERCOOLER: Custom CMC inter-cooled system (hand-crafted)
PRICE: $350,000 (USD)
añado :bash:
RALLY
No esta mal la bestia aunque 350.000 USD es un pastón con el que yo mejor me compraba otra cosa porque 810 HP y ese par tan descomunal, lo tiene que acabar rompiendo todo.
Esos si tiene pinta de estar muy bien hecho.
Dan Titan
Vaya brico!!. Con ese bicharraco habrá que tener cuidado con el pedal del gas, porque supongo que si lo pisas sin piedad, es capaz de hacer caballitos :mad:
Dan Titan
Estoy de acuerdo, un M5 es un M5 y no hay nada que añadir. Pero hay que reconocer el mérito de la idea y el curro correspondiente.
