;# EDIABAS 7.2.0 #
[Configuration]
Interface =STD:OBD
Simulation = 0
EcuPath =C:\EDIABAS\ECU
SimulationPath =C:\EDIABAS\SIM
TracePath =C:\EDIABAS\TRACE
TraceSize = 1024
ApiTrace = 0
IfhTrace = 0
; IfhnTrace = 0
; SystemTraceSys = 0
; SystemTraceBip = 0
; SystemTraceIfh = 0
; SystemTraceNet = 0
; BipDebugLevel = 0
; BipErrorLevel = 0
UbattHandling = 0
IgnitionHandling = 0
ClampHandling = 0
RetryComm = 1
SystemResults = 1
TaskPriority = 0
; CodeMapping = C:\EC-Apps\EDIABAS\BIN\ansi2oem.tab
; LoadWin32 = 0
NetworkProtocol = TCP
; --- neu ab EDIABAS 7.2.0 ---------------------------------------------------
ShowIcon = 1
LogLevel = 0
TraceBuffering = 0
TraceHistory = 0
TraceSync = 1
; TraceWriter = <FilePathName>
[TCP]
RemoteHost = LMUC203404
Port = 3000
TimeoutConnect = 2000
TimeoutReceive = 2000
TimeoutFunction = 10000
; TimeResponsePending = 5000
; DisconnectOnApiEnd = 1
; InitCmd0 = FE,04,00,03,01
; InitCmd1 = FD,05,00,03,01
[XEthernet]
RemoteHost = Autodetect
HeaderFormat = 0
TesterAddress = F4,F5
ControlPort = 6811
DiagnosticPort = 6801
TimeoutConnect = 20000
[IfhProxy]
Port = 6700
;## ausführliche Variante von EDIABAS.ini (mit Kurz-Info und Default) ##
; EDIABAS Basic Configuration
; [Configuration]
;### new Configuration elements since EDIABAS 7.2 ############################
; ShowIcon
; Description : Enable/Disable EDIABAS-Icon in System-Tray
; Value : 0 = EDIABAS-Icon disabled
; 1 = EDIABAS-Icon enabled
; Default = 1
; ShowIcon = 1
; LogLevel
; Description : Logging of fatal faults in EDIABAS.log
; Value : 0 = Logging disabled
; 1 = Logging enabled
; Default = 0
; LogLevel = 0
; TraceBuffering
; Description : Manner of Opening/Closing of Trace-Files
; Value : 0 = Opening/Closing after every dump
; 1 = Trace-Files stay open
; Default = 0
; TraceBuffering = 0
; TraceHistory
; Description : Number of History-Trace-Files
; Value : 0 .. 999
; Default = 0
; TraceHistory = 0
; TraceSync
; Description : Synchronisation of Trace files
; Value : 0 = Synchronisation disabled
; 1 = Synchronisation enabled
; Default = 1
; TraceSync = 1
; TraceWriter
; Description : FilePathName of a private TraceWriter
; Default = . (Default-TraceWriter "TWFile32.dll")
; TraceWriter = .
;### older Configuration elements till EDIABAS 7.1 ###########################
; Simulation
; Description : Enable/Disable ECU simulation
; Value : 0 = Simulation disabled
; 1 = Simulation enabled
; Default = 0
; Simulation = 0
; EcuPath
; Description : ECU file path
; Default = .
; EcuPath = C:\EC-Apps\EDIABAS\ECU
; SimulationPath
; Description : Simulation file path
; Default = .
; SimulationPath = C:\EC-Apps\EDIABAS\SIM
; TracePath
; Description : Trace file path
; Default = .
; TracePath = C:\EC-Apps\EDIABAS\TRACE
; TraceSize
; Description : Maximum size of each trace file [KB]
; Value : 0 .. 32767
; Default = 1024
; TraceSize = 1024
; ApiTrace
; Description : Enable/Disable API/User trace
; Value : 0 = Trace disabled
; 1 = User trace
; 2 = User trace + time stamp
; 3 = User trace + time stamp + process id (Win32)
; 4 = Function trace
; 5 = Function trace + time stamp
; 6 = Function trace + time stamp + timing
; 7 = Function trace + time stamp + timing + process id (Win32)
; 8 = Debug trace
; Default = 0
; ApiTrace = 0
; IfhTrace
; Description : Enable/Disable IFH trace
; 1 = User trace
; 2 = User trace + interface
; 3 = User trace + interface + time stamp
; Default = 0
; IfhTrace = 0
; IfhnTrace
; Description : Enable/Disable IFH network trace (with XREMOTE)
; 1 = User trace
; Default = 0
; IfhnTrace = 0
; SystemTraceSys
; Description : Enable/Disable system trace (runtime system)
; Trace levels 1 .. 7
; Default = 0
; SystemTraceBip
; Description : Enable/Disable BIP trace (runtime system)
; Default = 0
; SystemTraceIfh
; Description : Enable/Disable IFH system trace
; Default = 0
; SystemTraceNet
; Description : Enable/Disable network trace
; Default = 0
; BipDebugLevel
; Description : BIP debug level of ECU files
; Default = 0
; BipDebugLevel = 0
; BipErrorLevel
; Description : BIP error level of ECU files
; Default = 0
; BipErrorLevel = 0
; UbattHandling
; Description : Ubatt ON/OFF handling
; Value : 0 = Ubatt ON/OFF: No EDIABAS error
; 1 = Ubatt ON/OFF: EDIABAS error
; Default = 1
; UbattHandling = 0
; IgnitionHandling
; Description : Ignition ON/OFF handling
; Value : 0 = Ignition ON/OFF: No EDIABAS error
; 1 = Ignition ON/OFF: EDIABAS error
; Default = 1
; IgnitionHandling = 0
; ClampHandling
; Description : automatic check of clamps for Ubatt and Ignition
; Value : 0 = no automatic clamp check with send_and_receive
; 1 = automatic clamp check with send_and_receive
; Default = 1
; ClampHandling = 1
; RetryComm
; Description : Repeat failed communication automatically (1x)
; Value : 0 = Retry disabled
; 1 = Retry enabled (1x)
; Default = 1
; RetryComm = 1
; SystemResults
; Description : Enable/Disable system results (ubatt/ignition/jobstatus)
; Value : 0 = Disable system results
; 1 = Enable system results
; Default = 1
; SystemResults = 1
; TaskPriority
; Description : EDIABAS process/thread priority (only Win32/16)
; Value : 0 = Optimal EDIABAS performance = 8
; 1 = Minimal EDIABAS performance
; 10 = Maximal EDIABAS performance
; Default = 0
; TaskPriority = 0
; CodeMapping
; Description : Character mapping file path
; Default = .
; LoadWin32
; Description : Map EDIABAS Win16 calls to EDIABAS Win32
; Value : 0 = Win16/32 Mapping disabled (Win16-->Win16)
; 1 = Win16/32 Mapping enabled (Win16-->Win32)
; Default = 0 for Windows 9x/Me
; Default = 1 for Windows NT4/2000/XP
; LoadWin32 = 0
; NetworkProtocol
; Description : Network protocol
; Default =
; NetworkProtocol = TCP
; Interface
; Description : Connected diagnosis interface
; Default = EDIC
; Interface = STD:FUNK
; Additional information (in German) :
; Bitte beachten: Der HW-Treiber fuer das Interface muss installiert sein!
; Beschreibung : Funk-Diagnose Interface MDA von Fa. Siemens
; Installation : keine
; INI-Datei : FUNK.INI
; Unterstuetzung : WIN95,98 16-Bit : Nein
; WIN95,98 32-Bit : Ja
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Ansprechpart.: Daniel Haase
; Telefon : 089 / 382-43876
; email : Daniel.Haase@bmw.de
; Interface = STD:OMITEC
; Beschreibung : Nachfolger von OBD / enthält CAN-Anbindung / Anschluss an OBD-Dose
; Installation : \EDIABAS\HARDWARE\OMITEC\AnleitungfuerOMITECInstallation.pdf
; INI-Datei : siehe \EDIABAS\HARDWARE\OMITEC\Omitec_Doku.pdf
; Unterstuetzung : siehe \EDIABAS\HARDWARE\OMITEC\Omitec_Doku.pdf
; Ansprechpart.: Reinhold Drexel
; Telefon : 089 / 382-44236
; email : Reinhold.Drexel@bmw.de
; Interface = STD:OBD
; Beschreibung : Serieller Pegelwandler (Nachfolger von ADS / Anschluss an OBD-Dose)
; Installation : \EDIABAS\HARDWARE\OBD\ODBSETUP (nur noetig fuer WIN NT4, WIN 2000, WIN XP)
; INI-Datei : Suchreihenfolge analog zu EDIABAS.ini
; Unterstuetzung : WIN3.xx : Nein
; WIN95,98 16-Bit : Nein
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = EDIC
; Beschreibung : Anbindung über K-Line
; HW-Derivate : PC-Card, PCMCIA , W-LAN (Interface von Fa. Softing)
; Installation : \EDIABAS\HARDWARE\EDIC\SETUP.EXE
; INI-Datei : EDICFW.INI, EDICHW.INI
; WIN NT 4.0 : Ja
; WIN XP : Ja
; EDIC-PC, PCMCIA
; Ansprechpart.: Gerd Huber => EDIABAS-Hotline
; Telefon : 089 / 382-68878 (Hotline)
; email : Gerd.Huber@bmw.de
; EDIC-NET
; Interface = EDICC
; INI-Datei : EDICFW.INI, EDICHW.INI, XEDICC.INI
; WIN NT 4.0 : Ja
; WIN XP : Ja
; EDIC-PC, PCMCIA
; EDIC-NET
; Interface = STD:CAN
; Beschreibung : PCMCIA CAN-Interface CanCardX von Fa. Vector
; Installation : keine (ausser Installation der CAN-Karte)
; INI-Datei : CAN32.INI
; WIN95,98 32-Bit : Nein
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Ansprechpartner: Ralf Jusko => FLASH-Hotline
; Telefon : +49-(0)89/382-35891 (Hotline)
; email : FLASH.SERVICE@BMW.DE (Hotline)
; Interface = REMOTE
; Beschreibung : Anbindung eines EDIABAS-Interfaces über TCP/IP (für Normalbetrieb)
; Installation : Anpassung der Einträge in [TCP] auf beiden Seiten (ins.: RemoteHost, Port)
; INI-Datei : keine
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Remote-PC
; OP(P)S
; Ansprechpart.: Michael Rowedder
; Telefon : 089 / 382-29159
; email : Michael.Rowedder@bmw.de
; ICOM
; Ansprechpart.: Robert Schwinn
; Telefon : 089 / 382-10094
; email : Robert.Schwinn@bmw.de
; Interface = RPLUS
; Beschreibung : Anbindung eines EDIABAS-Interfaces über TCP/IP (für PROXY-Betrieb)
; Installation : Anpassung der Einträge in [TCP] auf beiden Seiten (insb.: RemoteHost, Port)
; INI-Datei : keine
; Unterstuetzung : ältere systeme : nicht freigegeben
; WIN XP : Ja
; Remote-PC
; ICOM (Fertigung)
; ICOM (Vertrieb)
; Interface = REMOTE:name
; Beschreibung : Anbindung eines EDIABAS-Interfaces über TCP/IP (für Parallelbetrieb)
; INI-Datei : REMOTE.INI (insbesondere für Parallelbetrieb notwendig)
; In REMOTE.INI stehen unter [name] spezif. Einstellungen(z.B.: RemoteHost, Port)
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Remote-PC
; OP(P)S
; ICOM (Fertigung)
; ICOM (Vertrieb)
; Interface = RPLUS:name (aktuell: RPLUS:ICOM)
; INI-Datei : RPLUS.INI (insbesondere für Parallelbetrieb notwendig)
; Beschreibung : ansonsten Analogie zu „REMOTE:name“
; WIN XP : Ja
; Interface = ENET
; Beschreibung : Anbindung über Ethernet
; Installation : Anpassung der Einträge in [XEthernet] (insb.: RemoteHost)
; INI-Datei : ENET.INI (insbesondere für Parallelbetrieb notwendig)
; WIN95,98 32-Bit : nicht freigegeben
; WIN NT 4.0 : nicht freigegeben
; WIN XP : Ja
; Interface = PROXY:<Interface>
; z.B. Interface = PROXY:STD:FUNK
; z.B. Interface = PROXY:ENET
; Beschreibung : EDIABAS wird im PROXY-Modus betrieben
; Installation : hängt vom benutzten Interface ab
; INI-Datei : hängt vom benutzten Interface ab
; WIN XP : Ja
; Konfigurationslemente, die existieren,
; aber nicht in EDIABAS.ini geändert werden können
; BipEcuFile
; Description : Dateititel der aktuell geladenen SGBD
; (nur gültig während einer Job-Verarbeitung)
; Value : String
; Default = -
; EdiabasIniPath
; Description : Pfad der verwendeten EDIABAS.ini
; Value : String
; Default = -
; EdiabasVersion
; Description : verwendete EDIABAS-Version
; Value : String
; Default = -
; IfhVersion
; Description : verwendete IFH-Version
; Value : String
; Default = -
; Session
; Description : Name der EDIABAS-Session
; Value : String
; Default = -
; TCP/IP Configuration
; [TCP]
; RemoteHost
; Description : server address/name
; Default = -
; RemoteHost = LMUC203404
; Port
; Description : IP communication port
; Value : 1000 < port < 30000
; Spezialfall OP(P)S / ICOM:
; Value : 6801 ;OBD-Treiber (CAN)
; Value : 6802 ;Most-Treiber
; Default = -
; Port = 3000
; weitere Details siehe Dokumentationen
; TimeoutConnect
; Description : Timeout for establishing the connection
; Value : 1000 ... 59000
; Default = 5000
; TimeoutConnect = 2000
; TimeoutReceive
; Description : Timeout for receiving a message
; Default = 5000
; TimeoutReceive = 2000
; TimeoutFunction
; Description : Timeout for a long function
; Value : 5000 ... 59000
; Default = 59000
; TimeoutFunction = 10000
; Description : Time between alive-messages
; Value : 500 ... 59000
; Default = 2000
; Description : Enable/Disable Disconnection with function call ApiEnd
; Value : 0 = Disconnection disabled
; 1 = Disconnection enabled
; Default = 0
; InitCmd<n>
; Description : Initialization command <n> (normally for OPPS)
; Default =
; XETHERNET Configuration
; [XEthernet]
; RemoteHost
; Value : Autodetect
; 169.254.1.1 ; Beispiel
; 192.168.100.1 ; Beispiel
; Default =
; RemoteHost = Autodetect
; IfhRemoteHost
; Default =
; IfhRemoteHost = Autodetect
; HeaderFormat
; Description : type of header
; Value : 0 ; 6Byte Header (B-Muster)
; 1 ; 3Byte Header (A-Muster)
; Default = 0
; HeaderFormat = 0
; TesterAddress
; Description : list of permitted tester adresses
; Value : F4 ; F1 durch F4 ersetzen
; F5 ; F1 durch F5 ersetzen
; F4,F5 ; F1 zuerst durch F4 ersetzen, dann F1 durch F5 ersetzen
; F5,F4 ; F1 zuerst durch F5 ersetzen, dann F1 durch F4 ersetzen
; Default = -
; TesterAddress = F4,F5
; ControlPort
; Description : port of control channel of TCP connection to ZGW
; Value : 1000 < port < 59000
; Default = 6811
; ControlPort = 6811
; DiagnosticPort
; Description : port of diagnostic channel of TCP connection to ZGW
; Default = 6801
; DiagnosticPort = 6801
; TimeoutConnect
; Description : timeout in ms for connection to ZGW
; Default = 20000
; TimeoutConnect = 20000
; XPROXY Configuration
; [IfhProxy]
; Port
; Description : IP base proxy port
; Ports : +0 = unknown interface
; +1 = EDIC
; +2 = EDICC
; +3 = ENET
; +4 = STD
; +5 = REMOT
; Default = 6700
; Port = 6700
; End Of File EDIABAS.ini
