Vendo Downpipe motor B48
maxwarmer
BMW ///M
2 Abr 2004
Buenas vendo downpipe para motor B48, sirve para varios modelos de coches, no lo llegue a montar, lo compre en el 120i pero lo vendi antes de montarlo, asi que lo pongo en venta.
Es valido para todos estos modelos:
Models[edit]
Power Torque Years
135 kW (181 hp)
at 5,000–6,500 rpm 290 N⋅m (214 lb⋅ft)
at 1,350–4,250 rpm 2016–
141 kW (189 hp)
at 4,700–6,000 rpm 280 N⋅m (207 lb⋅ft)
at 1,250–4,500 rpm 2014–
165 kW (221 hp)
at 5,000–6,500 rpm 310 N⋅m (229 lb⋅ft)
at 1,400–5,000 rpm 2016–
170 kW (228 hp)
at 5,000–6,500 rpm 300 N⋅m (221 lb⋅ft)
at 1,250–4,800 rpm 2015–
185 kW (248 hp)
at 5,200–6,500 rpm 350 N⋅m (258 lb⋅ft)
at 1,450–4,800 rpm
190 kW (255 hp)
at 5,000–6,500 rpm 400 N⋅m (295 lb⋅ft)
at 1,550–4,400 rpm 2016–
225 kW (302 hp)
at 5,000–6,250 rpm 450 N⋅m (332 lb⋅ft)
at 1,750–4,500 rpm 2019–
135 kW version[edit]
When combined with the electric motor, the 330e and 530e overall output is 185 kW (248 hp) and 420 N⋅m (310 lb⋅ft)[5] [6]
Applications:
  • 2015–present F30 320i
  • 2016–2018 F30 330e
  • 2016–present F20 120i
  • 2018–present G01 X3 xDrive20i
  • 2019–present G20 320i
  • 2019–present G20 330e
  • 2017–present G30 530e
141 kW version[edit]
In the MINI Cooper S, a temporary overboost increases peak torque by 20 N⋅m (15 lb⋅ft) to 300 N⋅m (221 lb⋅ft).[7]
Applications:
  • 2014–present F56 MINI Cooper S[8] B48A20A
  • 2015–present F22 220i
  • 2016–present F48 X1 20i
  • 2017–present F39 X2 sDrive20i
  • 2018–present G29 Z4 sDrive20i
165 kW version[edit]
  • 2016–present F20 125i
170 kW version[edit]
  • 2014–present F56 MINI JCW Hardtop and JCW Cabrio (320 Nm)[9]
  • 2017–present F56 MINI JCW Clubman and JCW Countryman ALL4 (350 Nm)
  • 2015–present F22 225i
  • 2016–present F48 X1 25i/28i
  • 2017–present F39 X2 25i/28i
185 kW version[edit]
  • 2015–2018 F30 330i
  • 2015–present F31 330i
  • 2016–present G30 530i
  • 2016–present F22 230i[10]
  • 2016–present F32/F33/F36 430i
  • 2018–present G01 X3 xDrive30i
  • 2018–present G02 X4 xDrive30i
  • 2018–present G29 Z4 sDrive30i
190 kW version[edit]
  • 2016–present G11 730i/730Li
  • 2017–present G11 740e xDrive/740Le xDrive[11] (combined with 82 kW electric motor for total output of 240 kW)
  • 2017–present G32 630i
  • 2019–present G20 330i
  • 2019–present A90/J29 Toyota Supra (Japanese SZ-R models)
225 kW version[edit]
In the BMW X2 M35i, engine features a reinforced crankshaft with larger main bearings and new pistons with a lower 9.5:1 compression ratio. This allows the engine to take more boost pressure from a larger turbocharger, which blows compressed air through a reworked intake tract.[12]
  • 2019–present F39 X2 M35i
Me costo 950€, lo vendo por 700€
https://esauc-my.sharepoint.com/:i:...tNv-Gd8FuKGGMBnxQ4W0Zaf9ToHD7o8_3Vfg?e=9X0KZ7
