Cuadro digital para modelos E de BMW (E81, E82, E87, E88, E90, E91, E92, E93, E60, E61, E63, E64, E6
x6Donald
335d M Performa
14 Oct 2012
Buscando por internet encontre esta web (indiegogo), que parecer ser un tipo de webs que ayudan a "mecenar", empresas o productos.
Encontre este producto que me parece increible para los BMW en la Gama E (E81, E82, E87, E88, E90, E91, E92, E93, E60, E61, E63, E64, E65, E66, E84, E83 E70, E71), y os pongo un poco de información. Me parece increiblemente bueno, ya que nos da las funciones de coches de ultima generacion con cuadros digitales tales como:
- Temperatura agua
- Temperatura Aceite
- Camara marcha atras integrada en cuadro
- Diferente configuraciones de color segun sea tu gusto
y muchas mas opciones.
Lo unico que a dia de hoy no esta en venta ya (parece que se cerro el plazo, hestoy intentando contactar con ellos para ver si fuera factible ahroa o en un futuro cercano poder adquirirlo e instalarlo
https://www.indiegogo.com/projects/bmw-retrofit-cluster/x/23385169#/
Do you like the look of an analog car dashboard but also like the features a digital dashboard gives you? Or are you simply looking to customize your ride? Then we have the perfect product for you!
Introducing the BMW Retrofit Cluster
This digital cluster is not only able to give you the look and feel of an analog dashboard -- it will also allow you the change the look of the whole dashboard with the switch of a button -- You can choose from different dashboard styles preloaded on the cluster and in future download many styles or add-ons on our website. Simply load them onto your USB and plug it in your cluster. It will automatically be updated.
This digital dashboard opens the door to so many more possibilities than any analog cluster ever could. The BMW Retrofit Cluster allows you to implement a near endless number of different skins and features like rear view camera options, customizable startup animations, instant MpH to KpH conversion and additional gauges just to name a few.
This is the ultimate must have for any BMW enthusiast who wants to spice up their ride.
The BMW Retrofit Cluster is almost in the last stages of product testing. Over 90% of the work has already been done so when you support our campaign you are guaranteed to receive your promised product. We only need the last push to take this product to a level where we and especially you will be satisfied with.
Not only will your support help us with further development and production of this cluster, but more importantly it allows us to start development of additional custom-made skins and features to give you the ability to completely customize your cluster to your taste.
At the moment we are able to offer the BMW Retrofit Cluster for the following models:
In addition to our retrofit cluster we will develop a unique cluster cover for the following models which makes this retrofit just like an OE cluster. This cluster will be delivered as a plug and play cluster for your car.
The unique cluster cover will ONLY be available for the following models:
E60, E61, E63, E64, E70, E71, E90, E91, E92, E93
For the E81, E82, E87, E88, E65, E66, E84, E83 models we don't offer a unique cluster cover but we will offer a bracket and gauge-plate to mount the retrofit cluster in your dashboard. For these models you have to do some rework on your original cluster cover to maintain the OE integrated look.
Our retrofit cluster for BMW is built upon ID4motion digital cluster platform which means that the entire product is developed and produced with Dutch quality. With our developed hardware, software and graphical user interface we can make anything what is attracting for BMW drivers.
The idea started more than a year ago while working for a large OEM that desperately was looking for a nicely integration of an LCD display in a vehicle dashboard. We integrated a 12.3-Inch display into a BMW E6x series attached with the original instrument cluster cover which made a perfectly solution for our project. But when starting this aftermarket project we faced some challenges.
  • The cluster has to fit different BMW models.
  • The 12.3-Inch display is hard to integrate in the dashboard because of the large size.
  • We wanted to have a more ‘open’ style of display without fixed rings (more freedom in design)
  • We needed to lower the cost price in order to have a better sales price for you.
In meantime we have changed our development to a 10.3-inch display which is smaller and also of “Automotive grade” and thus fits better for our aftermarket project. Because of the smaller size it now also fits the smaller dashboards like E9x and E8x. Everybody happy so far! Our estimation is that we are going to sell more displays since we have a wider target market, so we could calculate a lower price. The user will not notice the smaller display besides slightly different design, but still the same size of speed and RPM dials are possible. We also listened to you by leaving out the BMW fixed rings so we are now able to create more fancy graphical user interfaces. And finally, the development of a custom cover is now easier and cheaper.
Overall, we are happy that we have chosen this setup because we could all benefit from this!
Summary
- Standalone digital cluster with 10.3-Inch Automotive Grade display
- Behaves according to signals from BMW
- Optional unique cluster cover for a selection of BMW models, other models can choose for bracket and gauge plate
Functionality:
Speedometer, RPM, fuel level, outside temperature, date and time, odo and trip meter, cruise control, MPG gauge
Indicators:
Direction left and right, gears (automatic transmission), sportbutton (automatic transmission), high beam, LDW, cruise control, foglight front and rear, airbag, seatbelt, active steering, handbrake, brakefluid, DTC and ABS, check state, CE, TPMS
(Functionality is only working if vehicle has these options already available)
In the cluster menu you can manage following functions: metric/imperial (km/h / mp/h), brightness, change available parameters, change to available GUI (skin)
With the available USB port on the cluster you can do future feature or GUI updates. We are planning on some fantastic nice features soon.
After selecting a perk you are able to select add-ons. There are different add-ons available but these are depending on what is available for your selected cluster package. Please go through all the perks and add-ons before making your final choice. Available add-ons for example are: vehicle cable adapter, unique cover, bracket, your flavor of unique software updates like updated dials or adding a coolant fluid temperature or oil temperature gauge.
Warranty is 1 year and limited to replace of product or if ID4motion decides, a (partly) refund. No costs or liability for (dis)assembly or damage to vehicle or persons.
sUm02
2 Jul 2011
nadie ha respondido a este tema estando todos confinados?
Me parece una pasada si se llega a vender a todo el mundo, eso si, tiene pinta que costará una pasta.
JorgeSPV
325i e92
29 Ene 2018
Está muy guapo pero me parece muchísima pasta para lo que ofrece
x6Donald
335d M Performa
14 Oct 2012
Para mi gusto por lo que ofrece no lo veo caro
yo creo que a parte del cambio de estetica, incluir varias cosas que creo que deberia llevar de serie (temp aceite y agua) y darle una estetica mas moderna, no lo encuentro caro.
juanca_fg
E90 M47 y S1000
11 Abr 2011
Yo no soy de cuadros digitales, prefiero el analógico. Pero chulo está. Por lo menos conserva la esencia de los relojes.
Lo que no soporto son los nuevos con las revoluciones antihorario y demás "tontunas".
alexandre90
BMW 318D
13 Dic 2018
Yo contacte con ellos hace unos meses para preguntar el precio y me dijeron que iban a estar sobre 1000€
Tuku
e90 330XD
23 Nov 2006
Mola un montón, seria una modificación a tener en cuenta.
x6Donald
335d M Performa
14 Oct 2012
yo esta modificacion tambien la tendre en cuenta, mas que nada por el tema temeperatura del agua.
12 May 2017
Buenas, alguno lo teneis? Tiene pinta que es este:
https://customdigitalgauges.com/col...w-retrofit-cluster-e9x?variant=36569990987927
Yo llevaba buscando esto bastante tiempo, y lo único es que es un poco caro no?, al final no tiene software extra, y si quieres el skin guapo a pagar, o lo del agua... yo si hubieran sido 600-700 con todo... igual me había lanzado pero así... me gustaría saber más .
si alguno lo ha visto en vivo o lo tiene que comente please. O si tenéis otra opción similar (que puedas poner más cosas aunque no hay mucho espacio).
saludos
hi8aminidv
21 Ago 2014
Es muy interesante; pero me surge una duda: si instalamos este cuadro tendremos problemas en la ITV?, habría que homologarlo?
12 May 2017
No se si se podría homologar, seguramente pueda dar problemas, pero yo creo que si pones el skin que se parece al coche... ni se enteran, porque no es algo que se suela mirar, ni que se suela cambiar.
Quizás dependa sobre todo de si te preguntan los kms, o si se meten a mirarlos, que igual ahí canta un poco más. Ese es otro punto que estuve dandole vuelta... porque decirle que era un extra del 2007, igual no cuela jeje
LOGOPITO
530I E60
26 Dic 2020
Buenas tardes, refloto este hilo para hacer una pregunta. Estos cuadros digitales se "autoinstalan" cogiendo los datos del cuadro original, si por casualidades de la vida se estropea y hay que poner el cuadro de serie, éste cogerá los nuevos kilómetros y se quedará todo bien???
deirvy
e90 320d 184cv
4 Ene 2010
Hay que configurar un poco para que funcione todo, pero básicamente sí que son plug&play. Echa un vistazo al post de @OrlA en uno de la serie F:
https://www.bmwfaq.org/threads/cambio-de-cuadro-de-instrumentos-digital-chino-bmw-f30.1038716/
LOGOPITO
530I E60
26 Dic 2020
Muchas gracias por el enlace, se me había pasado
