Yo es que ese lo veo para rusos(discretos) en Marbella, honestly Y una mujer con ese reloj tiene que ser esta en sus mejores épocas
Esa fue anterior, con chuache, esta es de Rocky IV El pobre italian stallion no entraba por las puertas a lo ancho después, la tipa era un torbellino por lo que cuentan
Richard Mille y Airbus Corporate Jets (ACJ) presentan el RM 62-01 Tourbillon Vibrating Alarm ACJ, edición limitada de 30 unidades a millón y cuarto, dicen que es lo más complicado que han hecho hasta ahora, lleva una alarma que no suena, funciona con vibración regulada con varias intensidades y solo la siente el que lo lleva puesto Given the scale on which they each operate, you would not think horology and aviation have that much in common. Swiss watchmaker Richard Mille and Airbus Corporate Jets, ACJ for short, is here to prove you wrong: where mechanics and engineering are concerned, they are alike. Richard Mille’s Most Complicated Watch Is a Flawless Paradox The two companies first teamed up in 2016, co-designing the limited-edition RM 50-02 ACJ Tourbillon Split Seconds Chronograph, a timepiece that came with a jaw-dropping price tag of $1.05 million apiece and became a landmark in horology (and unlikely partnerships). In 2019, they teamed up again, this time for a piece that Richard Mille dubs the “five legged sheep” because of a new complication included in it (one that seemed impossible until that point), or the ultimate “paradox:” an alarm watch that no one can hear. Thus, this timepiece comes to defy the very idea that inspired it. The RM 62-01 Tourbillon Vibrating Alarm ACJ is also a limited edition and it’s the most complicated timepiece RM ever created – and given RM’s history, that’s no small feat. It took the team of builders at Richard Mille 5 years working full-time to bring the complication from design to actual development stage, and then to fully test it to see that it did not interfere with the other complications in the watch. RM 62-01 is an alarm watch, but one that no one can hear. Hence the paradox of the design. “Normally, an effective alarm needs to be audible from afar… Ours however, needed to remain within the compass of a few millimeters,” the watchmaker says. The idea, though simple, proved difficult to bring into a watch. The programmable alarm can only be felt by the wearer and it’s the first ever incorporated into this type of mechanism, made possible through a partnership movement makers at Audemars Piguet Renaud & Papi. Because it’s never been done, Richard Mille builders had to make sure the vibrations didn’t interfere with the manual winding movement. “The project has been something of a marathon because it is extremely complex,” Salvador Arbona, Technical Director – Movement, says. “These timepieces designed to take us into entirely new territory require mechanisms that entail many years of development. A vibrating alarm simply did not exist, so there was a very long phase of experimentation.” The RM 25-01 Tourbillon Adventure Watch, a Richard Mille watch designed with help from none other than actor Sylvester Stallone, is another example of one of these complicated timepieces Arbona is talking about. RM 25-01 doubles as a compass and comes with an interchangeable bezel. Back on the topic of RM 62-10, the result of all this hard work is a timepiece made up of 816 parts, including 2 barrels, 7 even hands, 11 displays and the tourbillon cage, encased in a caseback of steel and titanium. The bridges are made of titanium, while the oscillating weight that produces the vibrations when the alarm is triggered is made of one piece of solid gold. The bezel is made of steel and titanium, while the second bezel (designed to resemble an airplane window, in an elegant nod to Airbus) is made of Carbon TPT. With a power reserve of 70 hours, RM 62-01 is designed for the ultimate traveler: rugged, reliable yet still elegant. It’s outstanding both in terms of design and engineering, and the high-quality materials used. Moreover, rigorous testing guarantees its durability. Richard Mille has long been a standard of excellent watchmaking, but the RM 62-01 strengthens its position as a pioneer in horological experimentation. “The ability of our watches to function in hostile conditions, to resist considerable forces and to withstand wear and tear has led us to test our innovations by subjecting them to a ‘torture chamber’ we built at our manufacture,” Richard Mille says. “Like aviation, which demands a safety margin of 120%-150%, we want our watches to exceed all norms in terms of their functionality.” Only 30 copies of the RM 62-01 Tourbillon Vibrating Alarm ACJ have been made, retailing for $1,225,000.
Buenas. A ver si alguno de los másters de este hilo puede resolverme una duda. Estoy decidido en hacerme con un reloj de esmayao, pero que ha sido varias veces recomendado en el hilo como reloj de iniciación y por relación calidad precio. Se trata del Tissot Seastar 1000 Powermatic 80: https://www.tissotwatches.com/es-es/shop/seastar-1000-powermatic-80-correa-caucho-esfera-azul.html En la web de Tissot, aparece en la esfera, debajo del nombre del modelo, la indicación de profundidad máxima (30 bar (300m/1000ft)). En cambio en cualquier otra web de relojería me aparece sin dicha indicación. Por ejemplo en esta: https://www.joyeriainaki.es/product...veNVpnE--EZW3eV1ekhGeqXdjhFAJzhhoCbAAQAvD_BwE La referencia es la misma, y en todas las descripciones se especifica que es hasta 300 m, y todas las fotos son idénticas a las de la web de Tissot, excepto la de la esfera con la inscripción de profundidad. Me gustaría saber si hay alguna diferencia entre ambos de cualquier tipo o si es indiferente escoger uno u otro. Muchísimas gracias anticipadas y mis mejores deseos para todos para el 2020. Pd: mañana voy a Madrid de compras navideñas y me gustaría dejar resuelto el tema del reloj. Pd 2: soy consciente de que habrá alternativas mucho mejores, pero estéticamente me encanta, y mi tiesura actual no me da para mucho más.
De esmayao nada. Me parece una buena pieza relación calidad-precio. Me gusta bastante. Lo de la inscripción de la profundidad, es curioso, parece un mero tema estético, y solo aparece en la web oficial de Tissot. A mi no me preocuparía disfrútalo y ponte unas fotitos cuando tengas el reloj!
Yo creo que debe ser por el año de producción también,de todas maneras puedes mandar un Whatsap a la joyería que has puesto y pregúntales la duda,te quedarás más tranquilo. Buena compra calidad precio! Ya nos cuentas que tal.
Pero realmente sabéis los que es una profundidad de 300m? Yo buceo y lo normal es moverte entre 40-60m A 300m antes has muerto tu, a qué se ha jorobado el reloj
Habando de Tissot, Ayer ví en ECI el "Gentleman" y está bonito Líneas neutras, atemporal, elegante, tamaño comedido... me gustó mucho.
Mira usted qué casualidad, ayer estuve también en ECI mirando en la sección de relojería ¿te quieres creer que no vi nada que me dijese esto es "guao"? Le hice ojitos a un Longines Hydroconquest pero... Miré mi Oris y me dije, ¿para qué? Y hace tiempo que le hago ojitos, con bisel rojo.
Así en esas líneas y con bisel rojo si te gusta tienes el Glycine. Personalmente no me gusta la combinación de bisel giratorio de Diver con dial de números árabes. Es muy de los Swiss Military y los Victorinox. Si es tipo militar y dial con números árabes, prefiero que no sea tipo diver. O este Mido, que me encantaba
Señores, os dejo esto por aquí, por si os pudiese interesar. https://www.bmwfaq.org/threads/orient-star-revolver-y-seiko-mapmeter.986855/ Dos japos que vende un íntimo amigo de total confianza.
Más fotos en el anuncio de este enlace: https://www.bmwfaq.org/threads/orient-star-revolver-y-seiko-mapmeter.986855/
Vamos a ver, milord... Lo veo a 1100 mortadelos en ebay Italia, y de repente a 399 dólares en Ashford EEUU. Dónde está la mosca?
