Duda BMW M4 En NURBURGRING hagan sus apuestas (Tiempo).
jangel
Bueno pues aqui algo de info diciendo que al menos 10 segundos mas rapido que el E92
no esta nada mal para solo 10 cv mas jejejejeje
venga empiezo yo apuesto por 7,50 y si baja de ahí .............flipo
New Highlights
■ F80 M3 / F82 M4 are more than 10 seconds faster around the Nurburgring than the E90/E92 M3.
■ The M3/M4 were more or less built and developed around the steering. This electric power steering system (EPS) is the best that money can buy today. Our benchmark was to beat the current M3 in terms of steering feedback and we beat it (and there's not much out there that can claim to beat the current M3 when it comes to steering feedback and precision). The steering is very much an enjoyable part of the car and you will be able to enjoy it not just on the Nurburgring, but also just going to the office everyday.
■ Reported DIN weight is with standard brakes (not carbon ceramics).
■ Carbon ceramic brakes save 6-7kg (13.2lbs - 15.4lbs) overall. Not as much weight saved as on the F10 M5 with ceramic brakes, but that's because the caliper upgrade is much bigger than in the M5's situation. Here, we're seeing the calipers go from 4 piston front / 2 piston rear on the standard M3/M4 brakes to the 6 piston front / 4 piston rear calipers on the M Carbon Ceramic Brakes.
■ Automatic rev matching on the manual transmission is disabled in Sport+ mode. It's active in the Sport and Comfort modes.
■ Center of gravity is pretty much the same between the M3 and M4, but not identical since the two cars have different shock absorber settings. Both are a little lower than the 3/4 Series.
■ M3 naturally has an aerodynamically better shape than the M4 (if the M4 did not have its gurney integrated trunk) due to the M4's less steep and longer roof. The gurney flap integrated into the M4 trunk spoiler helps the M4 catch up aerodynamically.
■ New trunk lid removes 5kg (11 lbs) from the car instead of active rear spoilers which would have added weight to the car.
■ Manual transmission is a further developed gearbox from the 1M Coupe, with twin blade clutch, updated oil system and coating within the gearbox to take the higher load of the S55 engine. It's also lighter by more than 12kg (26.5 lbs) compared to manual gearbox in E90 M3.
■ Manual transmission gearbox saves 55 pounds in the US curb weight (compared to DCT).
■ Rear seats are 5kg (11 lbs) lighter than regular 3 or 4 Series.
■ Engine crankshaft is about 3kg (6.6 lbs) lighter than typical BMW inline 6 engine, but 20% stiffer.
■ Crankcase housing is 2.8kg (6.2 lbs) lighter. No steel liners. Unique aluminum alloy plasmacoated with steel plasma, which reduces friction levels. This technology was used on the M3 GTS with its upgraded 4.4L 450hp engine.
■ Car's components are engineered to withstand up to 1.4g braking force and more than 1.2g of lateral acceleration.
BEMETA LEGENDS
El M4 pesa 200kg mas :)
Ya cibermad... aunque pese 200 kg mas cosa que tengo que mirar por que el nuevo m4 es bastante ligero..... el cupra tiene un chorro de caballos menos y digo yo que la dinamica de un segmento coupe deportivo a compacto algo se notara.... bueeno pero veamos que pasa, yo tampoco me quiero aventurar mucho...
Gulf627
Buff...si es tiempo proporcionado por el fabricante 7:15 juasss si es tiempo "real", digamos de SportAuto, yo diria que 7:55 seria un buen tiempo.
Sobre el tema de los neumaticos, pensad que ahora hasta un Corsa OPC lleva semislicks...ningun fabricante se arriesga con este tema y todo dios le casca unos semis.
antuan
Para los "flipaos" del post.
Dato de SportAuto:
911 S (991) .......7:44
911 Turbo S .......7:34
Un tiempo brillante seria 7:50...bajar de ahi me parece dificil.
Esos tiempos son los de Horst vS?
Seria un buen golpe de efecto superar a todos los m3 previos (m3 CSL 7:50 - m3 GTS 7:48)
Y luego ya cuando saquen el M4X bajar a 7:42 jeje
Peibolote
Joer como van los turbo,que le mete 10segundos al v8.Mucho sonar,pero a la hora de la verdad...Lo de los 10segundos ya se comentaba hace tiempo.Veremos a ver, que tiempo hace finalmente :guiño:
Gulf627
Si son de Horst v. S....y si, sin duda seria una pasada que el F82 igualara a CSL y GTS...y seguro que la cosa esta cerca. Todo apunta que los nuevos M son dinamicamente la leche, y entre el aligeramiento, la mejora de frenos, y alguna cosilla mas seguro que hace un tiempazo.
Lo malo es que todavia habra que esperar entre medio anio o un anio hasta ver tiempo fiables en Sportauto.
Como aciertes te regalo un Carrera GT :descojon:
Lo quiero plateado a ser posible, aunque me da igual el color, es lo de menos :cool:
zeki
Venga yo apuesto por 7:48:23 (el 23 por la edad que tengo biggrin) pero vamos si consigue menos todavía será un buen coche ahora si se acerca mucho al del cupra, lo iguala o lo pasa ( esto si que no creo que pase) a la hoguera con el M4 j*der con son 150cv mas y un 6L turbo
Allí es donde he visto el único Carrera GT, los únicos Veyron, el único Enzo, el único SLR Stirling Moss...
