X5 LCI 3.0 Xdrive 2010
Tema en 'BMW Serie X5/X6/X7' iniciado por HORSE BMW, 25 Ago 2021.
  1. HORSE BMW
    HORSE BMW En Practicas
    20 Nov 2008
    E70 LCI
    Buenos días todos.
    Una ayudita, por favor.
    Me acabo de poner hacer los cambios de filtros, y pensaba encontrar fácilmente el filtro de gasoil y no lo localizo. Podrías indicarme dónde lo tenemos.
    Gracias a todos.
  2. elrinconoriginal
    elrinconoriginal Clan Leader Miembro del Club
    28 May 2007
    BOADILLA
    318D
    13 32 051Replace the fuel filter (M57T2, N52K, N57, N62TU) - diesel-engine cars and petral vehicles with SA1AK (outer located fuel filter)
    Special tools required:
    [​IMG] Important!
    Wear safety goggles and protective gloves.
    [​IMG] Necessary preliminary work:
    [​IMG] Recycling:
    Catch and dispose of escaping fuel.
    Observe country-specific waste disposal regulations.
    [​IMG] Note:
    Catch and dispose of escaping fuel with drip tray (1) and if necessary special tool 00 2 030 (universal hydraulic lifting equipment).
    Recycling:
    Release screws (1).
    Vehicles without fuel preheating only:
    Release clamps on front and back fuel lines on fuel filter.
    Disconnect front and back fuel lines from fuel filter.
    Close fuel lines with suitable plugs from set of special tools 32 1 270 !
    Remove fuel filter.
    Only M57T2 and N57 engine:
    Release clamps on front fuel line on fuel filter.
    Disconnect front fuel line on fuel filter and close with suitable plugs from set of special tools 32 1 270 !
    Pull out retainer (2).
    Disconnect fuel preheating (3) from fuel filter.
    Remove fuel filter.
    Installation note:Check clamps. Replace faulty clamps.
    Reassemble the vehicle.
    Before starting the engine, switch the ignition on and off several times until the electric fuel pump fills the fuel system.
    Check fuel system for tightness.
    Adjuntos:
  3. elrinconoriginal
    28 May 2007
    BOADILLA
    318D
    Home / BMW E70 X5 xDrive30d SAV / Repair Manuals and Technical Data / 13 Fuel preparation and control / 13 32 Fuel filter /
    51 47 491Removing and installing/replacing rear underbody protection
    [​IMG] Note:
    Illustration created using X5 3.0i as an example. There may be differences in detail in the case of other models.
    [​IMG] Release screws (1) and remove underbody protection (2).Installation note:
    Centre underbody protection (2) and tighten down screws (1).
    51 47 ...Removing and installing/replacing left or right underbody panelling
    [​IMG] Necessary preliminary tasks:
    Underbody panelling must not be jammed by vehicle hoist. If necessary, fit suitable blocks under vehicle jacking points.
    Note:
    Work shown on X5 3.0i by way of example, deviations in detail are possible in other models.
    [​IMG] Important with E72!
    Cover, side, six-cylinder models:
    Release screws/nuts (1 and 2).
    Feed out cover (3).
    Installation note:
    Ensure cover (3) is correctly seated.
    Underbody panelling, side:
    Release clamps (1).
    Release screws/nuts (2 and 4).
    Feed out underbody panelling (3).
    Installation note:
    If necessary, replace faulty clips (1).
    Fit clips (1) with O-rings.
    Make sure underbody panelling (3) is correctly seated.
    Underride protection, fuel tank:
    Release clamps (1).
    Release screws/nuts (2 and 3).
    Feed out underride protection (4).
    Installation note:
    Make sure underride protection (4) is correctly seated.
  4. HORSE BMW
    20 Nov 2008
    E70 LCI
    Buenas noches.
    Gracias compañero por la rapidez.
    Vaya manera de quitar plásticos y tornillos, pero bueno es lo que hay.
    Todo el día entretenido con el coche, sarna con gusto no pica.
  5. HORSE BMW
    20 Nov 2008
    E70 LCI
  6. HORSE BMW
    20 Nov 2008
    E70 LCI
    Super sencillo, cambiar los filtros de Aceite, polen, aire y gasoil, unos más entretenidos que otros, pero sencillos de cambiar.
    A Dimon le gusta esto.
