Buenas tardes, me gustaría me recomendaríais algún taller oficial en Barcelona, que sepan reparar eléctricos. Es para mirar la perdida de asistencia en la dirección en un i3s rex 2019. Muchas gracias de antemano
La solución parece esta (software update) y debería poder resolverse en cualquier servicio oficial: " We have an 2018 I3S that had steering problems for a year, the TSB procedure fixed the glitches and improved the steering feel overall. The TSB: https://static.nhtsa.gov/odi/tsbs/2019/ ... 5-9999.pdf "Update vehicle integration level to ISTA 4.20.1x, or higher" "Target Integration Level: I001-19-11-510 or higher" 11/4/2019 32 11 19_SPORADIC REDUCTION OF STEERING ASSISTANCE 1/3 SIB 32 11 19 SPORADIC REDUCTION OF STEERING ASSISTANCE 2019-10-30 MODEL I01 (i3) SITUATION The driver notices a reduction of steering assistance sporadically while in certain driving situations. Steering control is never lost when the reduction of assistance occurs. The fault may self-correct for no obvious reason or be eliminated with a terminal change/key cycle. There is no Check Control (CC) message when the issue occurs. CAUSE Unfavorable software in the Electric Power Steering (EPS). CORRECTION Update vehicle integration level to ISTA 4.20.1x, or higher and an optimized EPS software. PROCEDURE For conditions that are similar to the situation described: 1. Perform a vehicle test with ISTA and work through all relevant saved fault memory entries first. 2. Program the vehicle using ISTA 4.20.1x (available late October, 2019), or higher. Model Target Integration Level I01 (i3) I001-19-11-510 or higher Note that ISTA will automatically reprogram and code all programmable control modules that do not have the latest software. Always connect a BMW approved battery charger/power supply (SI B04 23 10). For information on programming and coding with ISTA/P, refer to CenterNet / Aftersales Portal / Service / Workshop Technology / Vehicle Programming. 3. After successful vehicle software update, submit TSARA case for IRAP session titled “i3 Sporadic Reduction of Steering Assistance”. WARRANTY INFORMATION Covered under the terms of the BMW New Vehicle Limited Warranty for Passenger Cars and Light Trucks or the BMW Certified Pre-Owned Program. Defect Code: 3213021400 Steering gear temporary malfunction Labor Operation Description Labor Allowance Copyright ©2019 BMW of North America, Inc. 11/4/2019 32 11 19_SPORADIC REDUCTION OF STEERING ASSISTANCE 2/3 00 00 006 Performing vehicle test (with vehicle diagnosis system – checking faults) (Main work) Refer to AIR Or: 00 00 556 Performing vehicle test (with vehicle diagnosis system – checking faults) (Plus work) Refer to AIR And: 61 21 528 Connect an approved battery charger/power supply (indicated in AIR as Charging battery) Refer to AIR Or: 61 21 529 Connect an approved battery charger/power supply (luggage compartment service cap removed to EME) Refer to AIR And 61 25 910 Recharging high-voltage battery unit (to high voltage charging socket) Refer to AIR And, as necessary: 61 00 006 Performing vehicle diagnosis – test module Work time (WT) And: 61 00 730 Programming/encoding control unit(s) Refer to AIR If you are using a Main labor code for another repair, use the Plus code labor operation 00 00 556 instead of 00 00 006. Refer to AIR for the corresponding flat rate unit (FRU) allowances. Work time labor operation code 61 00 006 is not considered a Main labor operation; however, it does require an individual punch time and an explanation on the repair order and in the claim comments section. During the same workshop visit, if a vehicle also requires another Technical Campaign or repair that also includes programming and encoding the control units, the programming procedure may only be invoiced one time. Programming and Encoding - Vehicle Control Units (RO and Claim Comments Required) The programming procedure automatically reprograms and encodes all vehicle control modules which do not have the latest software i-level. If one or more control module failures occur during this programming procedure: Please claim this consequential control module-related repair work under the defect code listed in this bulletin with the applicable AIR labor operations. Please explain this additional work (The why and what) on the repair order and in the claim comments section. For control module failures that occurred prior to performing this programming procedure: When covered under an applicable limited warranty, claim this control module-related repair work using the applicable defect code and labor operations in AIR (including diagnosis with separate punch times). Other Repairs Copyright ©2019 BMW of North America, Inc.
Por desgracia en Barcelona capital tienes pocas opciones de servicio oficial, pudiendo únicamente escoger entre las distintas filiales de Barcelona Premium. De todas ellas solo he probado la de l'Hospitalet y mi experiencia con un coche de combustión fue nefasta. Ahí yo no vuelvo. De donde más satisfecho he salido ha sido de Pruna Motor Mataró, pero hace más de dos años de mi última visita. Hablo siempre de coches de combustión, no tengo ningún i
Por casos que conozco en otras marcas en atención en los electricos son lamentable. En Madrid casi mejor ir a GT automocion, 80% electrico. En Barcelona ni idea si habrá sitios equivalentes.
