sobre el RDD IV
beemer
Mens insanus in corpore regulinchi
BMW R1200RT
6 Feb 2003
Interesante la tabla comparativa
:dan:
New Spectre IV, Spectre IV + Radar Detector Detectors
I’ve tested both new Stealth Microsystems Spectre RDD ™ Mark IV and Spectre RDD ™ Mark IV + (Stalcar outside the States) and found them each to be the best RDD ever.
The North America-only version Spectre Mark IV + differs from the Spectre Mark IV supplied to the rest of the world. It has enhanced filtering to automatically reduce detection range of the gross polluters from BG Tech (sold by Cobra, Early Warning and others) that set off the Spectre Mk IV constantly, due to their omnipresence.
This is a non-issue outside the U.S. where detector use is often illegal and there are few of them on the road. And the changes work: the Spectre Mk IV+ still detects the zillions of the noisy BG Tech models but at less range, making it far easier to live with. The VG-2, by comparison, is extraordinarily quiet. I can drive 500 freeway miles and only get half a dozen alerts. The reason is simple: it can’t detect any radar detector manufactured after the mid-nineties.
Both new Spectre/Stalcar RDD models were tested side by side to quantify differences in detection range. This showed which detectors are the easiest and toughest to detect. Keep in mind that the Mk IV tested had not yet been programmed to detect the new Whistlers. The Spectre Mk IV+ had the latest software, however.
Copyright © 2008 Craig Peterson
by exclusive permission of Applied Concepts, Inc. and Stealth Microsystems PLC
The new Spectre RDD ™ is a beautifully engineered piece of gear. Since its 2000 introduction and my first experience with it in Australia in early 2001, each model I’ve tested has been a refinement over the previous one. The latest versions are by far the best.
My advice to drivers illegally using a radar detector: choose your detector with care. Or be prepared to meet a guy wearing a gun and badge.
A
Aquelarre
beemer;5368508 dijo:
:dan:
Radar Detector versusSpectre Mk IV Spectre Mk IV + Beltronics (BEL) RX-65 Pro542ft (174m)722ft (233m)Beltronics (BEL) STi Driver0ft (0m)0ft (0m)Cobra 91104813ft (1604m)299ft (96.5m)Cobra 93301264ft (408m)30ft (9.7m)Escort Passport 9500i35ft (11.3m)33ft (10.6m)Escort Solo S21395ft (450m)232ft (85m)Valentine 1 (V1) v3.863171ft (55m)150ft (48m)Whistler Pro 78not tested434ft (140m)Whistler XTR 690not tested419ft (135m)Whistler 17634828ft (1557m)4810ft (1552m)Whistler 1788282ft (84m)289ft (27m)
Glups... xDD
j*der, este tio esta tan rallao como el inventor del multanova, vamos! A saber k le harían los coches a él!
2 Ago 2006
tu ponte un Sti o el filtro y olvidate de RDD;-), ademas las tablas están hechas en la mayoria con los peores detectores que existen digase cobra, whistler, s2
beemer
BMW R1200RT
6 Feb 2003
es curiosidad :descojon:
Cyph3r
8 Oct 2007
De Bel 975 no dice nada???
O sabeis mas o menos a cuantos metros lo detecta'??
S2
J
julian1982
y si lleva cono aun mas, pero suerte que ya tenemos el fistro. s2
M
mandible
Alucinado me dejan los 1500 y 1600 metros de un cobra y un whistler. ¿Qué llevan esos cacharros, una bocina exponencial para emitir a toda potencia? :descojon:
Lo curioso es que luego, a la hora de 'recibir', son de lo peor que hay #-obiggrin
8 Nov 2006
mandible;5369444 dijo:
Cuanta razón tienes.
Salu2.
