juanchuko
- Registrado
- 29 Ago 2009
- Mensajes
- 34
- Reacciones
- 0
Hola amigos,hace poco me decidi a cambiar la radio cd de mi bmw e87 por una convencional con mas utilidades:usb,parrot,mp3,...).El caso es que con una llave del coche va perfecta,pero con la otra ni enciende,yo creo que es que tengo que configurar la llave para que funcione.
Después de mucho leer artículos llegue a la conclusión de que lo que me hacia falta era el programa sss en el apartado ckm(car key memory) que tengo entendido que es donde se le pueden configurar tanto cosas del coche como de la llave.
Al final me decidi a comprar los programas y el cable necesario,que es este:
BMW, Mini, Rolls RoyceOBD USB Diagnostic interface
supporting models from 1998 to 03/2007
color="#ffffff">
Every single cable is checked on car before sending.
BMW Dealership software:
- BMW DIS v57 (Diagnostic Information System) used for diagnostic for cars before 2010
- BMW SSS v32 Progman (Software Service Station) used for programming for cars before 2006
- TIS (Technical Information System) containing all needed technical information
- INPA v5 & NCSExpert v3.1 used for diagnostic and codding for cars before 2010.
Conditions:
- Languages for DIS: English, German, Russian;- Languages for SSS: English, German, Russian, Spanish, French, etc..;
The kit is coming with English version of DIS. Russian and German version of DIS will be provided upon a request.
- DIS, TIS and SSS are preinstalled. You just have to copy them and start diagnostic.
- Video tutorial for step- by-step installation and written guide are included Also technical support is provided over TeamViewer!
- The 20pin adapter for older models is not included.
BMW DIS v57 - English
BMW SSS v32 Progman - English
Functions:
• Read fault codes• Erase fault codes• Service intervals/ inspections reset• Real-time data (live data) • Code modules• Code ECU functions (daytime running light, seat memory to key, beep after locking) • New battery registration after replacement• Specific part tests (like a lambda, mass air flow sensor, relays, valves…)• Activation self Test• And more...
Diagnose & Program Diagram
Supported models:
K-CAN models:
BMW 1 Series E87
BMW 3 Series E46 E83 E90
BMW 5 Series E39 E60 E61
BMW 6 Series E63 E64
BMW 7 Series E38 E65 E66
BMW X Series E53
BMW Z Series E85 E52
Mini R50, R52, R53
Features:
PC Requirements:
Your package will include:
• 2 x DVD's with DIS v57 & TIS, SSS v32, INPA Ediabas, NCSExpert 3.1• 1 x interface K like protocol
• 1 x Step-by-Step Guide with pictures + technical support over TeamViewer! • 1 x Step-by-Step Video guide
Lo instale todo correctamente,y funciona todo,pues no me sale ningún mensaje de error,y conecta con el vehiculo,pero en la sss en el apartado CKM(car key memory)no me deja acceder a el,esta el icono como blanquecino,y no me deja seleccionarlo,a alguien le a pasado esto?sera problema del cable?e provado el programa con el coche arrancado,no e conectado ningún estabilizador de tensión,alguien que me puede ayudar!Muchas gracias de antemano.
color="#ffffff">
Conditions:
Functions:
Supported models:
K-CAN models:
BMW 1 Series E87
BMW X Series E53
Mini R50, R52, R53
Features:
PC Requirements:
- Connects to USB
(1.5 m cable, creates virtual COM port) - Supports Double K-Line
- Supports High Speed CAN (500 kbit /s)
- Supports Low-Speed CAN PT (100 kbit /s)
- Detects battery voltage through control line
- Detects contact via control line
- Works on USB port.
- works on Win XP, Win7, Win 8(32bit & 64bit)
Windows 8.1 (32bit & 64bit) - USB port
- about 35Gb free hdd space
- 2Gb RAM memory
