Video Porsche 911 RSR (993) by CSF
Tema en 'Foro General BMW' iniciado por cybermad, 15 Jun 2024.
  1. cybermad
    $500,000 Porsche 911 RSR by CSF // REVIEW on AUTOBAHN
    9 jun 2024
    00:00 Walkaround
    06:11 Engine
    08:27 Interior
    11:30 Test Drive
    16:26 Autobahn
    Build specs:
    Engine
    Porsche 993 3.6 Liter Base Engine, Ceramic Coated Case
    Mahle Motorsports X LN Engineering 3.9 Liter Big Bore Cylinders & Pistons
    Crankshaft – Cross Drilled, Balanced & Micro Polished
    Pauter Lightweight Connecting Rods
    Pauter Lightweight Mechanical Rocker Arms
    Race Timing Chains
    Custom-Spec Purpose Built Camshafts by Webcam
    Cylinder Heads – Ported, Larger RS Valves, Race Springs, Titanium Retainers
    ARP Cylinder Head Studs
    Tarett Engineering Billet Valve Covers
    Tarett Engineering Semi-Solid Engine Mounts
    Porsche 991 GT3RS Titanium Exhaust Muffler, Valved
    Titanium 935 Style Exhaust Tips, Fabricated by SV Auto
    Hytech Tuned Headers, Ceramic Coated
    Clewett Engineering Serpentine Belt Drive
    Fiberglass 911 Engine Shroud Kit
    Ceramic Coated Fan Housing & Fan Blade
    Porsche 997 GT3 Oil Pump
    “Pro Gold” “Ac” Hose Ends & “Pro Gold” “Ar” High-Temperature Polymer Braid Engine Oil & Fuel Lines by BMRS
    Dual Engine Oil Cooler System by CSF Cooling
    OEM+ Right Fender Oil Cooler (CSF #8168)
    ‘73 Rs Style Front Center Oil Cooler (CSF #8201)
    Spal Electric Cooling Fans for Both Engine Oil Coolers
    G50 Transmission, Short Bell Housing Conversion by Patrick Motorsports, Ceramic Coated & Fully Restored
    CAE Racing Ultra Shifter for Porsche 993 With Custom Anodized Shift Knob
    Billet Transmission Differential Side Cover
    Wavetrac Limited Slip Differential
    Sachs Performance Clutch Kit
    Aasco Motorsports Lightweight Single Mass Flywheel
    Race Steel Synchro Rings
    Billet Transmission Bracket
    Turbo Drive Axles
    Bosch Coil On Plug Ignition System
    Motec M130 Engine Management with Numerous Fail Safe Features
    Rywire Motorsports Electronics Milspec Engine Harness
    Rywire Motorsports Electronics Power Control Module
    Kinsler Fuel Injection Porsche Gt Individual Throttle Body Manifold Package with Drive-By Wire & Motorsport Actuators
    Kinsler Billet Air Intake Plenum with Wiggins Ferrules, Anodized
    Custom Anodized Black Wiggins Clamps by BMRS
    AEM Fuel Pump
    Injector Dynamics 1050X Fuel Injectors
