Vendo Mercadillo E36 Otoño-Invierno 2014
Ppiyo
SupraMKIV
2 Ene 2008
Buenas familia,
he decidido abrir un mercadillo de piezas que he ido acumulando y almacenando con el tiempo ya que es hora de deshogar un poco el trastero.
Datos externos no permitidos. Info por el foro.
_________________________________________
ANTINIEBLA AMARILLO LADO IZQ. (PILOTO) MARCA ZKW - PRECIO: 30€
https://imageshack.com/i/idvOe67Nj
https://imageshack.com/i/kmXVxtbgj
VISCOSO PROCEDENTE DE UN M3 E36 (286CV), COMPRADO NUEVO EN EL CONCE HACE 2 AÑOS APROX. POR VALOR DE MAS DE 300€ CON 2000 KMS DE USO. REGALO PALAS VENTILADOR TAMBIEN NUEVAS PERO CON ROZADURA LEVE. (FUNCIONA TODO PERFECTAMENTE) - PRECIO :130€
https://imageshack.com/i/f0d9DsQhj
https://imageshack.com/i/pade5UrAj
POMO EN PIEL NEGRA EN PERFECTAS CONDICIONES, TIENE LA PLACA ALGO DESCENTRADA PERO NO SE DESPEGA NI SE MUEVE. -PRECIO: 35€
https://imageshack.com/i/pdZTkNbBj
https://imageshack.com/i/idUpV7Zwj
RADIO CASSETE ORIGINAL BMW CON CODIGO. FUNCIONA PERFECTAMENTE PERO LA RULETA SE PERDIO Y LE PUSE UN DEDAL ARTESANAL PARA PODER SUBIR Y BAJAR EL VOLUMEN. TIENE LA PIÑA Y ALGO DE CABLE POR SI PRECISA EMPALME A LA INSTALACION DE CUALQUIER COCHE -PRECIO: 25€
https://imageshack.com/i/iqYpu87Wj
GRUPO ABIERTO 188MM RATIO 2,93 PROCEDENTE DE MI 328 CON 144.000 KMS Y CON MUY BUEN USO.
https://imageshack.com/i/p50Um3paj
TAPACUBOS METALICOS PARA LLANTAS DE CHAPA. VALEN PARA TODAS LAS LLANTAS.IDEAL PARA STEELIES O CLASICOS. -PRECIO 45€
https://imageshack.com/i/kmoB3vz6j
SPOILER REPLICA M3 CON 3a LUZ DE FRENO EN LED. CABLE RENOVADO. - PRECIO 55€
https://imageshack.com/i/nrmpukj
https://imageshack.com/i/mup8q7j
https://imageshack.com/i/idc7TNmtj
TAPIZADO GOMA DE MALETERO ORIGINAL PARA E36 TOURING. SOLO VALIDO PARA ESTA VERSION. VA SUPERPUESTA EN LA MOQUETA ORIGINAL, COMO MUESTRA LA IMAGEN-PRECIO: 30€
https://imageshack.com/i/idINKzz1j
https://imageshack.com/i/f0T6us8Hj
ADMISION M3 286CV COMPLETA. HABRIA QUE RENOVAR JUNTAS, Y ALGUNA GOMA DE LAS TROMPETAS. TIENE ROTA UN TAPON DE GOMA COMO SE VE EN LAS FOTOS. - PRECIO 150€
https://imageshack.com/i/kppiyjBnj
https://imageshack.com/i/f06Wo7E2j
https://imageshack.com/i/eyCZEj0hj
https://imageshack.com/i/paodbAknj
https://imageshack.com/i/pbID79uNj
https://imageshack.com/i/ip3uTPzej
TRANSMISION CON FLECTOR EN BUENAS CONDICIONES M3 286CV. SIN HOLGURAS Y EN PERFECTAS CONDICIONES. PRECIO 120€
https://imageshack.com/i/ipRhIcOij
https://imageshack.com/i/kptoc0Uvj
https://imageshack.com/i/ipXoHeUHj
TENGO TAMBIEN GRAPAS, TORNILLOS, DESPIECES DE FAROS, RAMPA 6 CILINDROS, CONECTORES, BOTONES VARIOS, ADMISION 318IS, VOLANTE MONOMASA PARA 4CILINDROS ALIGERADO ETC. MUCHAS COSAS QUE NO VOY A DETALLAR AQUI. PREGUNTAR SIN COMPROMISO.
UN SALUDIN,
Ppiyo
SME36
Bmw M3 e36
24 Oct 2012
Tio de fiar 100%!!
Ppiyo
SupraMKIV
2 Ene 2008
Muchas gracias colega.
Ppiyo
SupraMKIV
2 Ene 2008
Volante vendido. Subimos!
