Iluminación [ayuda]tengo q montar un piloto trasero. Es muy complicado?
cromo320
25 Feb 2006
Algun desguace, sabeis q pueda tener original
elrinconoriginal
318D
28 May 2007
Home / BMW F25 X3 sDrive18d SAV / Repair Manuals and Technical Data / 63 Lights / 63 21 Rear light cluster /
63 21 170Removing and installing/replacing left or right rear light (in side wall)
(ESD protection).
EQjzlJ9J
Carefully slide trim (1) upward somewhat and remove toward luggage compartment.Installation note:
Make sure cover (1) is correctly seated.
Unscrew nuts (1).
Tightening torque 63 21 5AZ.
Remove rear light (2) towards rear.
EQxw6ZMy
Unfasten plug connection (1) and disconnect.
Remove rear light (2).
Installation note:
Make sure rear light (2) is correctly seated.
cromo320
25 Feb 2006
(ESD protection).
EQjzlJ9J
Unscrew nuts (1).
EQxw6ZMy
Installation note:
Muchas gracias
wiltor
27 Ago 2008
No te preocupes que es muy sencillo quitar la para que cubre las tuercas y una vez que las tieens fuera sale sin probelmas, desconectas la ficha y ya esta.
