ALPINA B3 S BiTurbo 405cv
Tema en 'Foro General BMW' iniciado por cybermad, 3 Mar 2010.
  1. cybermad
    :xray: :xray: :xray: :xray: :xray: :xray: :xray: :xray: :xray: :xray: :xray: :xray: :xray: :xray: :xray: :xray: :xray: :xray: :xray: :xray: :xray:
    :xray: :xray: :xray: :xray: :xray: :xray: :xray: ¡¡¡¡LO FRUTERO ES BELLO!!!!! :finga:
    Innovative, turbo-charged automobiles have always played a central role in ALPINA’s more than 45-year history as a manufacturer – the 1989 BMW ALPINA B10 Bi-Turbo is an excellent example, having achieved true cult status. In 2008 the BMW ALPINA B3 Bi-Turbo rekindled this tradition, combining Bi-Turbo charging with the compact dimensions of the BMW 3 Series.
    In 2010, the new BMW ALPINA B3 S Bi-Turbo combines improved performance and torque with reduced fuel consumption and CO2 emissions – it is the logical result of continuous engineering development at the highest level. Building upon the highly-praised traits of its predecessor, it presents itself as one of the most harmonious and multi-faceted sports cars in its segment.
    Alpina-B3S-Biturbo-E9x-08
    Whether Saloon, Coupé, Touring or Convertible, whether rear-wheel drive or all-wheel drive – the B3 S Bi-Turbo marries explosive performance with a high level of comfort and everyday usability, addressing the needs of an unusually broad target group of automotive enthusiasts:
    Information on fuel consumption and CO2 emissions according to 1999/94/EG:
    Saloon Touring Coupé Convertible
    Fuel consumption, combined: 9.7 l/100km 9.7 l/100km 9.7 l/100km 9.7 l/100km
    CO2 emissions: 224 g/km 225 g/km 224 g/km 225 g/km
    Chassis & Suspension
    Typically ALPINA, the chassis and suspension offer a unique blend of sport and comfort.
    The light, agile and direct handling of the B3 S Bi-Turbo is immediately noticeable. An ideal 50:50 front/rear axle weight distribution in combination with carefully chosen suspension components make for a great overall chassis set-up, which is equally engaging and comfortable. Stiffer rear axle suspension mounts, for example, increase steering precision and feedback, especially noticeable during fast lane changes.
    Low profile conventional tyres which forego Run Flat technology in favour of comfort in combination with light weight alloy 18″ or 19″ ALPINA wheels ensure that unsprung mass is kept to a minimum.
    Design
    Fine, elegant lines and a tasteful presence. The dynamic appearance of the B3 S Bi-Turbo is in part defined by the modern and functional front spoiler. Engineered using the newest developments in aerodynamic design, the spoiler reduces lift at the front and enables optimal air flow to the high performance cooling system. The coupé and convertible carry a new rear valance which communicates a tasteful sporting charm through its integrated rear diffusor and two distinctive double-ended exhaust pipes, a little like the stern of powerful luxury yachts.
    A fresh, evolutionary design with a clear heritage. The new ALPINA CLASSIC 19“ light-alloy wheels underline the finely-proportioned forms of the new B3 S Bi-Turbo models. Reminiscent of a turbine and with a three-dimensional sweep, each of the 20 spokes leads from the hub right to the edge of the rim, making for a very fluid and dynamic appearance even when motionless. Unique: the new design retains the hidden air valve mounted in the wheel centre, which is covered by a lockable hub cover, leaving the wheels flawless in their form and beauty.
    The comprehensive level of standard equipment convinces: leather sport seats offer excellent lateral support and comfort on long journeys, the ALPINA SWITCH-TRONIC leather sports steering is luxurious to the touch, the blue ALPINA instrument display provides additional information such as engine oil temperature and a digital speed indicator.
    Dimensions
    Length (mm) 4545
    Width (mm) 1817
    Height, unladen (mm) 1422
    Wheelbase (mm) 2760
    Track front (mm) 1503
    Track rear (mm) 1512
    Luggage capacity DIN (l) 450
    Fuel tank capacity (l) approx. 63
    Weight
    Weight, unladen (kg) 1570
    Permissible gross weight (kg) 2090
    Permitted payload (kg) 520
    Max axle load, front (kg) 1005
    Max axle load, rear (kg) 1120
    Max trailer load limit, braked (kg) 1700
    Max trailer load limit, unbraked (kg) 750
    Engine
    Cylinders 6 in-line
    Displacement (cc) 2979
    Bore (mm) 84.0
    Stroke (mm) 89.6
    Compression ratio :)1) 9.4
    Max output (kW/hp) 294 / 400
    at rpm (1/min) 6000
    Max torque (Nm/rpm) 540 / 4500
    Engine management Siemens MSD81
    Fuel type Super plus
    Emissions classification Euro 5
    Transmission
    Gearbox 6-speed Sport-Automatic ZF 6HP19 TÜ SWITCH-TRONIC
    1st 4.17
    2nd 2.34
    3rd 1.52
    4th 1.14
    5th 0.87
    6th 0.69
    Final drive ratio 3.46
    Performance
    Acceleration 0-100 km/h (s) 4.7
    Top speed (km/h) 300
    Fuel consumption *
    Urban (l/100 km) tba.
    Extra urban (l/100 km) tba.
    Combined (l/100 km) 9.7
    CO² emissions (g/km) 224
    Wheels and tyres
    Standard wheels and tyres ALPINA CLASSIC 18″ / MICHELIN Pilot Sport 2
    front 8 x 18 245/40 ZR18
    rear 9 x 18 265/40 ZR18
  2. Miguel de Cervantes
    Miguel de Cervantes Forista
    16 Sep 2008
    Gran Canaria
    RX8 + Triumph
    ¿Comooooo?:-s
    ¿¿¿¿¿A un 3.0 6L le sacan 400 Hps?????#-o#-o
    Que tomen nota los ingenieros de BMW.:-k
  3. Manolo71
    Manolo71 Forista Senior
    4 May 2008
    Tarragona
    M3E46,545E61
    Una vez mas,gracias por el reportaje Cybermad...:)P)
  4. pikas
    pikas Forista Senior
    4 Sep 2006
    madrid
    sera con el motor del 335 , pero vamos que un chiptuner tambien le saca ese caballaje , si oficialmente ese coche se vendiese con esa potencia , que seria del M3
  5. Ivanm34248
    Ivanm34248 Guest
    q maravilla....sin palabras
  6. 0ldboy
    0ldboy En Practicas
    6 Sep 2006
    A Coruña
    Precioso y deportivo sin llegar a perder clase.Calidad.
    No me creo los consumos.Y tampoco me gusta la caja automatica,hicieron igual con el z8 y creo que se equivocaron.
  7. M_Quero
    M_Quero Baneado Baneado
    12 Dic 2007
    Costa del Sol
    sin palabras , preciosos los coches
  8. dacubo
    dacubo Forista Senior
    6 May 2005
    PALENCIA CON "P"
    B3 3.3 Coupe
    Bueno bueno...maquinón en toda regla.biggrinbiggrin
    ALPINA ya tiene experiencia en motores BITURBO, (El B10 fue en su dia la berlina mas rapida del mundo¡¡¡).
    Si ya el de 360cv estaba ya en cifras de M3 E-90 este lo superara sin duda alguna.
    Que ganas de leer una prueba de este coche (aunque sea en alemán...):)P):)P)
    Por cierto si las cosas van bien, creo que mi B3 ya tiene un digno sustituto.:ang:
  9. AwuS
    AwuS Forista
    5 Jun 2008
    Cylinders 6 in-line
    Es sólo un 3L???
  10. dacubo
    6 May 2005
    PALENCIA CON "P"
    B3 3.3 Coupe
    Si, el motor esta basado en el 335i pero conveniente retocado.
    Alpina no solo se dedica a reprogramar (como cualquier preparador), todas las piezas estan estudiadas y reforzadas para soportar el cambio de potencia.
    Alpina otra cosa no pero sus motores son muy valorados por su fiabilidad.
  11. thecrow
    thecrow Clan Leader
    1 Abr 2004
    Al noreste...
    E84 X1xdr18dA
    algún día..., algún dia....:)P):)P):)P):)P):)P)
  12. tizuuu
    tizuuu Forista Legendario
    22 Jun 2008
    Cantabria/Asturias
    130i e87
    y pòr que no sacaran la serie 1 alpina :eek:
  13. blaki
    22 Ene 2007
    Curva de Gauss
    340 DIESEL
    El frutero que bruto :xray:
  14. Jover
    Jover Forista Legendario
    3 Feb 2004
    ///Madrid
    325tds/330ciCAB
    quiero uno me da igual el color
  15. tj50
    tj50 Guest
    Tiene que ser una gozada:notworthy:conducir un Alpina....
  16. TML
    TML Forista Senior
    20 Nov 2008
    Qué maravilla!!! :rockerito Pero para mí con estas llantas, las demás no me convencen:
  17. Lokko
    Lokko Forista
    25 Ene 2005
    A ver si en los e90/e92/e93 sacan alguna unidad con cambio DKG, en los e46 sólo vi una unidad en manual y el resto todos automáticos, pero ninguna SMG....una lástima!
    Quiero un alpina con cambio secuencial!
  18. BMWorks
    BMWorks Baneado Baneado
    12 Ene 2010
    Debajo de un puente
    No me convence para nada!
    Y a ver si Alpina empieza a cambiar ya esas llantas un poco anticuadas y sosas que no pegan para nada con un e93 ( desde mi punto de vista).
  19. erchechuuu
    erchechuuu Forista Legendario
    3 Jun 2005
    madrid
    :rock::rock::rock:
    madre mia madre mia madre miaaaaaaaaaaaaaa
  20. craclex
    craclex Guest
    Que preciosidades por favor
    Alpina forever!!
  21. julio bmw
    julio bmw En Practicas
    27 Ago 2009
    37.47324,-4.442943
    X3 F25M
    Como no iba a ser alpina, alpucinante
  22. *NANO*
    *NANO* Clan Leader
    El coche es impresionante, pero no entiendo el motivo por el que ponen los emblemas tan antiestéticos y grandes detrás (Alpina B3S Biturbo).
    Creo que con un "B3S" en pequeñito bastaría.
  23. Sargento_Duke
    Sargento_Duke Clan Leader
    2 Oct 2005
                                   truppenuebungsplatz
    ALLRAD??? no jodas que hay version 4x4 del B3s!!!
    Ese motor pasa a bmw dentro de nada :guiño: poco mas que alpina es el cento de pruebas de bmw.
    Sino de donde salio el 3.5d??? o el 4.5i???
    Brutales todos
  24. Chicharro
    Chicharro Forista Senior
    12 Feb 2004
    En la meseta
    Si que me gustaria ver la prueba del aparatito!!!!
    Por cierto los retrovisores del restyling no pueden ser mas feos que forma de j*der la marrana..........
  25. cybermad
    lo hay en version trasera y AWD, como tambien el D3 BITURBO y el B7 BITURBO biggrin
  26. mosca
    mosca Forista Legendario
    11 Oct 2009
    más feos que pegarle a un padre...
  27. CS_Tii
    CS_Tii Forista
    10 Nov 2009
    Cigales (VA)
    ALPINA SIEMPRE!!!!!!! Que bestialidad!!! chulisimo!!!!!
  28. rusbel
    rusbel Guest
    comparto opinion contigo, el distintivo de modelo que ocupa mas de medio porton le queda como una patada en los guevos, en su lugar cambiaria el emblema de bmw por el de alpina y nada mas, el que lo sabe valorar lo reconoce igual biggrin
  29. bmw_xxl
    bmw_xxl Forista
    12 Abr 2009
    MaDrId
    son preciosos me encantan bonitos cacharitos...
  30. tnp69
    tnp69 Clan Leader
    2 Feb 2007
    León
    Passat B8 Sport
    Preciosos los coches
